LSD found - Transmission Forum
LSD found
Saturday, September 02, 2006 12:44 PM
Re: LSD found
Saturday, September 02, 2006 1:37 PM
Nothing new. You can get the same thing from Team Green
Jason
99 Z24
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
Re: LSD found
Saturday, September 02, 2006 2:37 PM
I just figured it was one to post.
Re: LSD found
Saturday, September 02, 2006 2:39 PM
The Team Green has stiffer springs, in the neighborhood of 900 lbs, which will handle more torque before slipping.
Re: LSD found
Sunday, September 03, 2006 6:32 AM
and its cheaper
Re: LSD found
Saturday, September 09, 2006 4:25 PM
Well, it's $200 for Team Greens insert. That doesn't specify if you get a whole diff. or just an insert.
Re: LSD found
Saturday, September 09, 2006 4:30 PM
JuggaloZeke wrote:Well, it's $200 for Team Greens insert. That doesn't specify if you get a whole diff. or just an insert.
Ummmm....dude....look at the top of the page. Clearly says "Phantom Grip Limited Slip." PG ONLY makes inserts.
5K PB: 24:50
10K PB: 54:26
Re: LSD found
Saturday, September 09, 2006 4:44 PM
yup.. the PG is only an insert that simulates a LSD. If you want a real LSD get a Quaife... if they make them for j-body cars.
I can get a PG kit for my Saturn for about $150 less, but the trans i bought already has a welded diff pin so i cant put it in unless i get a new diff.
'95 Saturn SL2a
'06 Chevy Silverado 2500 Turbo Diesel
'07 Chevy Impala SS
Re: LSD found
Saturday, September 09, 2006 4:47 PM
Ummmm........dude.......maybe that company builds the whole differential.......never know.
Re: LSD found
Sunday, September 10, 2006 9:09 AM
PG only makes inserts, it's common knowledge to many on here. Team Green makes a similar insert, with stiffer springs, and I believe stronger alloy metal, for less $$.
