clutch wont disengauge - Transmission Forum
Wednesday, May 17, 2006 2:43 PM
i cant figure this out....in my driveway if u put the clutch to the floor and try to put it in reverse...u cant cause the clutch is still spinning......
i just had this transmission put in a week ago by a pro.........
i was told the slave cylinder wasnt bled enough....
is that wat could cause this or does sumthing need to be tightened or loosened.....
any help appreciated
you scratch my ride IMA EAT YO CHILDREN
Re: clutch wont disengauge
Wednesday, May 17, 2006 2:44 PM
and yes i put the clutch in 1st before moving to reverse....but it still spins and wont stop
Thursday, May 18, 2006 5:11 AM
Sounds odd that someone who knows what they are doing idn't bleed the slave? Try that first and then see what happens. Is reverse the onyl gear you can't shift into? If so then it might be a linkage thing.
Thursday, May 18, 2006 1:00 PM
Is it a new slave?
Thursday, May 18, 2006 1:39 PM
i went and he bled the slave...it had alot of air in it....much better now tranny runs fine....thanx for all the suggestions
Thursday, May 18, 2006 3:42 PM
Your definition of pro may be off a little, but I've heard they are biatches to bleed.
Thursday, May 18, 2006 7:21 PM
well hes certified...its a local shop....
Thursday, May 18, 2006 8:00 PM
Yeah I was just kidding, other than hearing the clutch is a pita to bleed. Glad you got r done
