Does anyone know how much to torque the flywheel and pressure plate bolts for the ecotec? I have a spec stage 3 and RK light weight flywheel, but cant find how much to torque them down. I tried searching but i can't seem to find an answer. If someone can help, I'd appreciate it.
Thanks
Josh
SLK 32
I just did it on my 2.4..... but cant remember it off the top of my head..... it was something low, plus 45*...... I think 20ft/lbs plus 45* on the flywheel..... but I'll look at the manual tonight if I remember.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Im also wondering what specs are on bolts which hold clutch plate to flywheel, any input much appreciated,
thanks,
i just looked it up in this haynes book and the closest thing i can find is this:
Clutch pressure plate-to-flywheel bolts: 2.2L 180 in lbs, then rotate 30 degrees...
im not sure what the hell that means or if its the right bolts... pm me, or im me if you wanna help me find it in this book, lol... good luck
I found it in another threat, supposively 18 ft lbs, I guess well see if that holds
Just made sure there was plenty of locktite, the bolts are very small. My guess is 180 in lbs + 30 degrees is somewhat close to 18 ft lbs. Thanks!
np!
