ok so yesterday this started...shifted from 1st to 2nd all nice and fine...got to about 3000 rpms and it popped out of 2nd into neutral. so i put it back into 2nd...popped back out after a sec. did it again and it went in and was fine. Since then, over the last day it's gotten alot worse, only 2nd gear. I did a run of it shifted hard from 1st to 2nd to see if that was ok...goes from 1st to 2nd chirps tires and all then popped out after a few seconds. And has been popping out quite a bit every time it's in 2nd. Any help would be appreciated.
sounds liek a synchro is goin out
Its the little detents inside of the First/Second Syncro that are worn out.
'99 2200 LS CX1 Sport
expensive to fix?
you hafta remove the trans to fix...so you can imagine
You could fix it yourself with the proper mechnical knowhow, but its allot of work.
