need more gears :( - Transmission Forum
need more gears :(
Wednesday, June 08, 2005 6:33 PM
anyone know of a six speed that will work with a 03 2.2 ecotech?
Elmer the wricer hunter..."Shhh be vewy vewy quiet...I'm huntin wrice"
Kill da wriiiicer...Kill da Wricerrrrr..kill daaa wriccceeerr!!!
Re: need more gears :(
Wednesday, June 08, 2005 6:37 PM
The closest bet would be a six speed from a Saab Eco, but its not drop in.
Wednesday, June 08, 2005 6:38 PM
~wondering how hard it would be ...hmmm
Wednesday, June 08, 2005 6:44 PM
j/w, but why do you need more gears?
<img src="http://thespork.dataride.com/theorg/sig.jpg">
Visit The Spork
Wednesday, June 08, 2005 7:25 PM
I hit 110 at like 4500-5000rpm..if i only had one more gear it would be smooth sailing..I think that everytime it does that...grrrrrrr..long 10 mile streaches of nothing gives you all kinds of room to play~LOL~sorry i dont go that fast to race..just cause i want it faster for my peice of mind..~missing my old 70 nova~
Wednesday, June 08, 2005 7:39 PM
Its called the speed limiter, thats not the transmission topping off, its the car stopping you from going any faster.
Wednesday, June 08, 2005 9:10 PM
You NEED to go faster then 110...?
Thats an impound waiting to happen, lol
its not a speed limiter..I ..huthmmm disabled it and ran a diffrent speedometer....but anyways....ok now ill probably get all kinds of @!#$ from everyone about..i dont care..im not a stupid 18 yearold kid~LOL~..just a 28 yearold that acts like one~LOL~
Wednesday, June 08, 2005 9:18 PM
I know the 00-05 Cavalier have a limited which stops it at 108 at 5200RPM's or around there, cause thats when my kicks in. You can run a different speedometer all you want and it won't change a thing. The rev limited/govenor is all programmed into the ECU. Flash the ECU if you want to get rid of it, but it'll destroy your warranty if you have one/.
Wednesday, June 08, 2005 9:28 PM
Changing your speedometer doesn't change your speed limiter.
Thursday, June 09, 2005 5:31 PM
but if your speed limiter is disabled..which also disables the speedometer ..i had to run a new speedometer
Thursday, June 09, 2005 11:39 PM
108mph is plenty for me personally.. even with the supercharger. Until i hit my speed limiter in the 1/4 mile its staying... there for i got a lot of work to do before i hit that.
As for your question for 6 spd... it would be kind of sweet just for a nice low highway or cruising gear maybe raise your gas mileage some on the high way? would be kind of kewl to see..
driving the Trans Am doing high way speeds in 6th im only at about 1800rpm
Supercharged 2.4L
Friday, June 10, 2005 1:36 PM
The speed limited does not disable the speedometer.... I told you, the limiter is in the ECU, it has nothing to do with the cluster...
Friday, June 10, 2005 3:48 PM
No, at 108 at the VSS signal. The fuel cuts. If you disconnect your cluster, your still gonna get cut off 108. You have to disable the VSS Signal to trick the car. But then you will have no speed indication so I call . Unless you have all custom computers in your car.
Saturday, June 11, 2005 4:59 PM
hahaha..its on the trans~LOL~
Saturday, June 11, 2005 5:00 PM
but it also diables your odometer
