Advice on TB for GM S/C - Boost Forum
Monday, November 14, 2005 8:48 AM
Many companies offer 56, 59, 60, 62, and even as high as 65mm. So which would you all recommend with the combination of a GM S/C?
Curious to know what is the size of the opening of the S/C too?
Lastly, where did you people bought yours?
Thanks
>>>For Sale? Clicky!<<<
Re: Advice on TB for GM S/C
Monday, November 14, 2005 9:18 AM
The bigger the better. If you go bigger than a 62mm, you'll have to port the end of the s/c to match the TB.
Monday, November 14, 2005 9:31 AM
i originally heard a long time ago that the s/c inlet is 60 mm. others have claimed 62. since [i think] it was 60, i bought a 59 locally. plus, it would work on the stock manifold until i bought the s/c (cuz some say the 62 hits the intake manifold opening).
i have had no problems with the rsm 59, including idle and just everything.
Monday, November 14, 2005 9:39 AM
im using a 59mm on mine currently
ive run the best of a 14.52 @ 94 in my cav , with a auto trans
Monday, November 14, 2005 12:37 PM
62mm(rsm) here and loving it.
Tuesday, November 15, 2005 9:11 AM
Thanks people.
RSM does not make a 59mm anymore right?
Also by going 62-65mm don't you think you will be stifling air velocity? I think by having that size you loose bottom end-torque but gain in high HP. Correct me if I am wrong.
Tuesday, November 15, 2005 1:19 PM
get the 62mm and be done with it. You have a s/c. why are you worried about torque?
Tuesday, November 15, 2005 1:25 PM
i have an rsm 62mm tb for sale
Tuesday, November 15, 2005 6:58 PM
listening.....
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
Wednesday, November 16, 2005 5:44 AM
Pending on how much boost you are running is how I would match a T/B. If you are planning on 8lbs and higher deff a 62mm. Lower boost a 56 or 59 would be fine. WIth the M62 kit and 15 lbs we are gonna be running a 75mm LS1 t/b on Blacks Z24
2002 Z28: Slp coldair Pac, Corsa Catback, 3200 stall
Wednesday, November 16, 2005 7:05 AM
im running STOCK PULLEY and hitting 6psi even when its hot as hell out and now its cold and im seeing like 6.5psi with the 59mm t/b.
Wednesday, November 16, 2005 9:45 AM
RSM 62mm here...loving it
Portage, MI
Wednesday, November 16, 2005 11:41 AM
jsunfireGT2000 wrote:im running STOCK PULLEY and hitting 6psi even when its hot as hell out and now its cold and im seeing like 6.5psi with the 59mm t/b.
you know, you post this in every post thats even remotely related to psi or pullies. have you ever thought that perhaps your boost gauge is off?
try a different gauge and see if you get the same results. if you do, props to u.
Wednesday, November 16, 2005 12:29 PM
Mr. Pute wrote:The bigger the better. If you go bigger than a 62mm, you'll have to port the end of the s/c to match the TB.
I agree 100%. But i believe the RSM 62mm throttle body actually only measures 60.5mm which is the same size as the blower inlet.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Wednesday, November 16, 2005 12:30 PM
..mine would hit 6 some times.... but right at red line.
Chris
'02 Z-24 Supercharged
Wednesday, November 16, 2005 1:00 PM
Yep mine was just a hair over that when I measured it.
Thursday, November 17, 2005 9:48 AM
Ya I measured it and it is exactly 60mm, I can attest.
But you guys brought up something interesting, the 62mm TB is really 60.5 mm.
Can someone really confirm that (maybe with a pic too)? Or was that just a isolated incident, because RSM clearly states "62mm."
Also the 59mm one is no longer made, correct?
Thanks for the input people.
Saturday, November 19, 2005 11:17 AM
(!) Info on this^^
Saturday, November 19, 2005 8:42 PM
I have the RSM 62mm, but have never measured it with a micrometer to verify it's actual size. I did notice that there is a small lip on the blower inlet that is visible through the TB opening. When I yank the S/C out to change my alternator, I'll probably machine that lip off.
With this TB and the 2.7" pulley, I've touched 8psi on a couple of occasions.
14.330 @ 96.37mph
Saturday, November 19, 2005 9:07 PM
I have a RACETECH "62mm" TB....
Measured it's actually 62.8 mm.... not some BS 60mm crap.
I've been saying this for almost 3 years, nobody listens.
If you want a true 62mm + TB.... Racetech sells 'em.
The bigger the better for boost!
-Chris-
-Sweetness-
-Turbocharged-
Saturday, November 19, 2005 10:16 PM
62mm lines up perfect.... 7 psi stock pulley on these great 30 degree nights can only imagine wat 10 feels like ahh
-marc
FS: GM's M45 Supercharger kit.. xcavix@hotmail.com
Monday, November 21, 2005 10:01 AM
Ok but unless you ported to a bigger diameter anything bigger then 60mm is useless as the air from larger opening of the TB will crash kinda like a wall to the smaller inlet of the S/C, airflow is then restricted.
So does RSM's really measure 60.5mm or 62mm?
Also looking at the opening of the S/C there is not much room to widen it.
Monday, November 21, 2005 11:19 AM
illd9 wrote:7 psi stock pulley on these great 30 degree nights
Same here, car feels amazing, 2nd gear actually scared the @!#$ out of me one night going through an empty parking lot!
Tuesday, November 22, 2005 10:24 AM
