Help Please - Boost Forum
Help Please
Thursday, October 27, 2005 1:35 PM
My supercharged Z24 has a slight problem. If I tap the gas from an idle it will come back down and either surge or stall. Sometimes it does this when I come to a stop. I just replaced the IAC, both O2 sensors, and TPS. Anybody got a clue what would cause this?
Re: Help Please
Thursday, October 27, 2005 1:36 PM
My car does this all the time. Check your plugs.
Re: Help Please
Thursday, October 27, 2005 2:11 PM
They are new plugs gapped at .040. ACDelco
Re: Help Please
Thursday, October 27, 2005 3:20 PM
Aren't they supposed to be 0.050?
Re: Help Please
Thursday, October 27, 2005 4:13 PM
OK I just put some Denso Iridium plugs in it and it runs so much better. They are gapped around .045. I didnt want to change the gap in fear that I might break an electrode because they are so small.
Re: Help Please
Friday, October 28, 2005 1:18 PM
After the car warmed up it started to do it again. The plugs didnt do anything. I ama running out of ideas.
Re: Help Please
Friday, October 28, 2005 11:42 PM
too rich? whats fuel looking like?
cavaliers been laid to rest
The saturn is being born
a new cavalier is in the mist
Re: Help Please
Saturday, October 29, 2005 12:12 AM
Even though you said yo replaced it, it still sounds like a TPS problem. Check the electrical connections and probe the back of the plug to see what it is reading.
Cardomain|Myspace
Re: Help Please
Saturday, October 29, 2005 1:47 AM
on my scan tool it reads 0% at idle and 100% at WOT and is accurate in between.
Re: Help Please
Saturday, October 29, 2005 6:04 AM
When my bike does that, I've got the pilot jets open a little too far. You're probably too rich at idle. How do your plugs look? Any black smoke when you blip the throttle off of idle?
Re: Help Please
Saturday, October 29, 2005 7:53 AM
plugs look normal. Light brown and not wet. no black smoke, but just under redline at wide open throttle it will puff a little black smoke. Also at WOT it runs rich.
Re: Help Please
Saturday, October 29, 2005 8:32 AM
check your vacuum lines for leaks, cracks, crimps, missing or loose lines.
2006 Black Cobalt SS Supercharged G85
13.91@102.77
Re: Help Please
Saturday, October 29, 2005 11:55 AM
I have checked over every vac line in the car. everything is in order. I am thinking it might be the Fuel pressure regulator.
