I have read on here about people having problems when they put in a Bosch O2 Sensor. What Exactly would the car do? I have a Bosch in mine and i don't want to replace it if i don't have to.
DCStang67 wrote:I have read on here about people having problems when they put in a Bosch O2 Sensor. What Exactly would the car do? I have a Bosch in mine and i don't want to replace it if i don't have to.
Are you having any problems?
The car seems like it doesn't have the power it had when i first put in the supercharger. When it is cold it hesitates when i take off. I have had this problem ever since my tps @!#$ the bed. I replaced it and adjusted it so that it reads 0% on my scan tool when the throttle is closed and 100% when at full throttle. Since then I have replaced both o2 sensors and it seemed to be a little better when i replaced the primary o2 sensor.
I havent have problems with my bosch, so im not sure.
I recently installed a new bosch o2 for my upstream. Ever since that it misses at cold startup and also hesitates when taking off, and between gears.
Bert Wert wrote:I recently installed a new bosch o2 for my upstream. Ever since that it misses at cold startup and also hesitates when taking off, and between gears.
i have that exact same problem half the time. only thing you can do is to avoid touching the sensor probe during installation, or replace it.
hell ya.. AC delco all the way...
Chris
'02 Z-24 Supercharged
