I know theres someone on this forum that has done this, i plan on getting a set of brown tops to up the fuel a little (42 would be too big for me and i think 30 are too small) so i want to be comfortable with 37lbs brown tops, But they are low impedence. The ecotec needs high.
SO how do you make them high impedence injectors?
I am in the same boat, i found those parts you listed for 2.50 a piece does that right and also can anybody else verify this information.
so how do you hook these up in-line? anyone got pictures?
You could easily handle the 42 pounders. Turn down the FPR and use the FMU raise it up with boost. Or use the SAFC2 or Emanage. Fuel isn't something you want to skimp on.
O noes!
i have my base fuel pressure at its lowest now. And i still need a SAFC. maybe ill get 42lbs when i get my SAFC so i dont need to rig mine fuel wires up for low imp. injectors
inline with the power wires going to the injectors
