So the ford injector clips have a red/black wire and a solid colored wire (blue , red, yellow, or purple)
The stock injectors have a solid grey wire and a black/other colored (lt blue, pink, lt green, and one solid black)
When wiring in ford injector clips, do the ones with red/black go to the ones with black stripes, or do the red/black ford clip wires go to the grey wires from the car??????
I'm pretty sure the black striped go to the black striped, but just wanted to make sure.
so either way would work, or do you think you just got lucky and picked the right side?
i think he means to look at how the stock clips are on now, and you take the wire thats on the left side of the clip, cut it and connect it to whatever wire is on the left side of the ford clip, and same with the right side. pretty easy, just match it up.
_________________________________________
450WHP Turbo Ecotec swap in the works...
Thanks! It works like a champ. The added fuel has made a night and day difference.
And ANYONE with the RSM blower on a 2.4........... I HIGHLY recommend the GM 2 bar map, and reflash, with the 310cc injectors.
