This is probably a really easy question but I have searched and searched and found nothing. I need a 2bar map sensor. Where can I get one and what is the part number. Could I use one from say...a 99 3000GT? I work at napa so wouldn't I just be able to look one up for ANY turbocharged vehicle? Please help. thanks. I have a 96 Z24 BTW.
So what do I do? Is my only option sending out my ecu? What can I do? I will be using apexi safc and programmable mis dis 2.
For the programmable you can ADD a 2 bar map sensor by simply plugging it into a manifold vaccum source and then plugging the DIS-2 harness into it... this way the Programmable dis 2 can see boost and the stock computer still has its garbage 1 bar sensor.
-Chris-
-Sweetness-
-Turbocharged-
^^ yup exactly what i was going to say
Ok...thats good. I will be able to retard the timing according to boost but how is my ecu with the safc going to be able to accomodate the fuel with the boost? Do I just program tha safc to certain rpm's??? I will also have a sfmu and afpr. Please...any info would be great.
SunfighterGT wrote:For the programmable you can ADD a 2 bar map sensor by simply plugging it into a manifold vaccum source and then plugging the DIS-2 harness into it... this way the Programmable dis 2 can see boost and the stock computer still has its garbage 1 bar sensor.
-Chris-
that sounds like your best plan!
