Here are some common questions what most people have that I had them clear up for us.
What size injectors are included and what brand?
- Accell/270cc
What brand of fuel pump and how much HP it supports (I think its 500)?
- Walbro 255lph
What brand FMU is included?
- Cartech w/5:1 ratio
How would you guys recommend tuning an Ecotec? Is a SAFC, wideband air/fuel gauge, and Greddy E-Manage “piggy back” system sufficient?
- We tune by the fuel management unit only! SAFC will not work with a map sensor.
How much more would it be to upgrade a turbo on the kit to a 20G vs. a 16G if possible?
- When purhcasing the kit the 20G is only $199 more!
Does that intercooler mount behind a stock bumper (2002, 2003, and 2004)?
- Yes, without cutting
Why was that style (inlet outlet on same side) intercooler used vs. the “in one side out the other” style?
- Better flow w/o utilizing long runs of i/c pipes, and better cooling characteristics
What size piping is used in this kit?
- 2 1/4"
Why was a Mitsubishi 16G chosen for the kit vs. the 20G turbo?
- Better spool up , for lower boost levels. 20G has more lag.
Last, can we get some more/better pictures of the kit?
- We will have some shortly with the web update!
CavalieRX wrote:Here are some common questions what most people have that I had them clear up for us.
- Accell/270cc
- Walbro 255lph
- 2 1/4"
Thought it was 330 cc injectors.. and it was an inline fuel pump . . . . but I could be wrong . . . .
- Accell/270cc
wrong. they are 32-34 lb/hr which is roughly 330cc
- Walbro 255lph
wrong. it is an inline pump. not the walbro 255.
believe your wrong again. its a BEGI with a 6:1 ratio.
had to correct a few things.
5K PB: 24:50
10K PB: 54:26
Um guys.. thats straight from Hahn.. So im pretty sure everything is 100%. But thanks though...
im doing my install right now... im too lazy to go out to the garage but the pump is DEFINITELY inline. no question about it. quoting hahns instructions: fuel tank/stock pump -> quick release fitting -> new inline pump -> fuel filter -> fuel rail.
I can forward you guys the email if you think the info is off. Thats all coming out of Hahn's mouth.
ive installed all the fuel mods on my friends 03
the fuel pump is inline
the fmu he got is a begi
the injectors are 32lb accels
i know what i installed , and what i listed is what i put on
now if hahn changed someting recently , the rest of us might not know about that
yea 270cc is like 20 cc above stock that cant be right
i dont need to call them AGAIN. i just talked to them recently about something else and talked to them for a few hours before i ordered my kit. the things i corrected i know to be true of any kit ordered up until this time. now if they did switch to the walbro 255 i think im gonna have to go get me one ASAP!
5K PB: 24:50
10K PB: 54:26
HYPSY you are 100% correct. hahn must be smoking some crack or he asked about a diff car.
TURBO KIT...$4,000
RUNNING 20 PSI...ANOTHER $2,000
SMOKING THE TIRES ON A 3RD GEAR ROLL...PRICELESS
Wow... this is crazy.. I guess Brad from Hahn just lied to me. This was a complete waste of time. I get info that most people will want to know and you guys think its all false. As of Thu 6/16/2005 10:18 AM (when I receive the email), this is what they told me about the kit. Last time I try and do anything benifical for this Forum.
Still it remains they are all right its the
BEGI 6:1
inline fuel pump
and 330 cc injectors
Also installed myself so i'm sure of it
well i would talk to Bill or ...ummmm...umm...the tech guy. those are the only two id listen to. sorry man but Bill happens to be a friend of my boss so I know my answers are right.
5K PB: 24:50
10K PB: 54:26
CavalieRX wrote:Wow... this is crazy.. I guess Brad from Hahn just lied to me. This was a complete waste of time. I get info that most people will want to know and you guys think its all false. As of Thu 6/16/2005 10:18 AM (when I receive the email), this is what they told me about the kit. Last time I try and do anything benifical for this Forum.
dude all i can tell you is what i installed , no reason to get pissy about it
i know what was in the boxes , and what the read , and what i installed
the tank was never droped , and the pump was installed next to the tank
what reason to hypsy , the others , and i have to lie about ???????????
absolutely NOTHING !!!!!!!!!
Not calling you a liar, but what about the possibility that they change the kit? Maybe they found a better combination of parts. Who knows. At least consider that. All that info I got directly from Hahn. None of it is off the top of my head. That'd be putting stupid on their part to give me false info. I personally like the parts that you guys said it comes with. But again... This is what they told me. You email them and see that they tell you.
well if they changed te kit to include a walbro 255 and 270cc injectors they just killed the kit. if they just changed to the walbro that would be a huge improvement...that pump is awesome. but for some reason i think Brad is wrong.
5K PB: 24:50
10K PB: 54:26
What are the numbers on the 20G psi and hp. How much of a difference is that than the Super G 16
Dave
A new breed of J will be unleashed in 05
Creating the E-RACER one mod at a time
Member of J-Factor
Member of Wisc's J's
1/4 mile 16.084 @ 84.90 (Stock Z) 01 SPDY Z24
Forward that email to eng@turbosystem.com so Bill can see what douchebags he has working for them. I've never talked to a shop that had more inconsistent info than them.
270cc injectors would be a total waste of time that might support 4psi if that
Anthony,
I see i made a few mistakes as far as the following information I listed last week. (and got slayed on j.body for the wrong information) I don't know why I put down the Eclipse stage 2 component info for injectors and fuel pump, but let me clear up my mistakes please!!!!!
- Accell/335cc
- Accel 500hp inline booster pump.
- Cartech w/5:1 ratio stage 2, and 7:1 ratio stage 1
Also, I don't know if I mentioned in an earlier e-mail that the system are on sale currently for the summer! NOW $2495 stage 1 , and $3495 stage 2!
Looks like they did make a mistake. I guess I can forgive them.
how much does the hahn turbo kit cost and how does it compare to the turbo kit from cavalier connection?
tad cherry wrote:how much does the hahn turbo kit cost and how does it compare to the turbo kit from cavalier connection?
Id say its a step above. The CC kit is 2450 base and 995 more for intercooler. Thats 3500 with NO fuel upgrades. Hahns is 3850 reg price and 3500 on sale right now. Hahns a bigger company... more money for RnD. Personal opinion.
Walbro makes both in tank and inline 255 pumps--I have an inline 255 in my hand as i type this.
