As the title states guys, I need to know quickly, if anyone has a pic it'd be much appreciated
it inbetween the tb and the cam cover directly in the intake
it has 3 wires going into it , and to remove it from the intake you have to twist it
Thanks, I found it
Cheers
right above the TB looks like a stick of gum
is the map sensor itself off to the right of the engine, I put my check valves on the vaccume line going to the cylinder shaped thingy off the intake manifold. Is that the right spot?
Jeff, if you cant find it, either Steve or I can point it out to ya. Im really lookin forward to seeing your setup and chattin boost, as Im a fellow 'pegger who's boostin his ecotec too. Anyhow, drop me a pm if you wanted me to point it out, but its pretty much just on the Intake mani just above the TB.
That would be great if you could show me where that thing is but I have a spare one in my room on my injector harness and it just dosen't seem like that could be it. Get my number off steve if you want. I just don't want to post it over the org. Good hearing from you man hopefully I can be some help with your project.
Jeff we found your map sensor, and that is where it is, lol..
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/stevefiresig.jpg"></a>
