GM S/C Reflash - Boost Forum
GM S/C Reflash
Tuesday, March 22, 2005 1:20 AM
I've searched and found nothing to help. where have people had there ECU reprogrammed with the GM s/c reflash? and around how much should I expect?
_________________________________________
450WHP Turbo Ecotec swap in the works...
Re: GM S/C Reflash
Tuesday, March 22, 2005 10:18 AM
only Gm dealerships can do it, most of the time they wont do it unless you bought the Gm charger, otherwise expect to pay anywhere from 40-100 dollars.
2006 Black Cobalt SS Supercharged G85
13.91@102.77
Re: GM S/C Reflash
Tuesday, March 22, 2005 5:12 PM
^He is right, but the price is depending on the dealer for 1hr labor work.
>>>For Sale? Clicky!<<<
Re: GM S/C Reflash
Tuesday, March 22, 2005 7:29 PM
has anyone on here gotten it done without buying the kit?
Re: GM S/C Reflash
Tuesday, March 22, 2005 7:31 PM
Spilner521 wrote:has anyone on here gotten it done without buying the kit?
Yes they have.... what year car do you have?
Re: GM S/C Reflash
Tuesday, March 22, 2005 10:16 PM
99
Re: GM S/C Reflash
Tuesday, March 22, 2005 10:21 PM
I have a 99 alero...but i wouldnt think the ecu in an alero would be that much different than that of a cavy..i've heard possibly gear ratios are different but thats it. would that affect the reflash at all?
Re: GM S/C Reflash
Wednesday, March 23, 2005 12:34 AM
I might be wrong, but i think you can only do it to 2000+ jbodies, alero's and grand am's with the 2.4L engine
Re: GM S/C Reflash
Wednesday, March 23, 2005 1:10 AM
I guess i'll just have to check around at some of the dealers around here....i'll see what i can come up with. anyone else that knows anything about it, any help would be much appreciated.
Re: GM S/C Reflash
Wednesday, March 23, 2005 4:24 AM
Yes, Freebs is right, you can only do it to the 2000+ cars, since the 99-'s had a different computer setup than the 00+'s
Re: GM S/C Reflash
Wednesday, March 23, 2005 10:06 AM
Is it ONLY for the 2.4L or could I have it done since I have a 2002 SFI(2.2L)?
Re: GM S/C Reflash
Wednesday, March 23, 2005 10:22 AM
It is only for the 2000+ 2.4L engine, will not work on the 2.2.
Re: GM S/C Reflash
Wednesday, March 23, 2005 10:24 AM
what exactly does the reflash do? any body running them on a turbo'd cavi
Re: GM S/C Reflash
Wednesday, March 23, 2005 10:30 AM
It allows the 2.4 guys to use a 2 bar map sensor and the GM supercharger injectors without an FMU or adjustable FPR.
Re: GM S/C Reflash
Wednesday, March 23, 2005 1:58 PM
I am using one. There is no proof of it doing anything. But on jeff filkins dyno sheets it looks like it automatically raises fuel pressure according to boost psi from the two bar. and i beleave that it also pulls timing too. But noone knows for sure what else it does. I bought a complete reflashed pcm from a jbo member with a auto charger reflash. I got lucky as heck. And yes I am turbo . First automatic to have the reflash with a turbo setup. As far as the 5 speed guys i think there were only a few before me. Brian speedracerZ. Jeff Filkins. kane5576 , me , and maybe a couple others that are turboed and running the reflash... All the others run it on the supercharger. It is only for 2000 + 2.4 Liters automatic and manual have different flashes too.... Hope that helps. Good luck finding someone to do it.
<img src="http://img.photobucket.com/albums/v292/dragmyz24/shoppedcav2.jpg">
Rush Racing http://www.gettherush.com/
Re: GM S/C Reflash
Wednesday, March 23, 2005 8:30 PM
Thanks for all the help. I'll make some calls..
Re: GM S/C Reflash
Wednesday, March 23, 2005 11:21 PM
Yea the re flash also changes the timing when the engine starts to receive knock... not until your getting over 6psi though (i got that info from a buddys dyno sheets with the 6psi and 8psi pulleys, as there was like a 2hp gain from 6-8psi because he was getting knock)... then you need a way to cool down the charged air... like alcohol injection or Nitrous
