GTP Injectors? - Boost Forum
GTP Injectors?
Tuesday, February 16, 2016 4:03 PM
I'm having my motor tuned next week. This is a new build 99 s10 2.2. I was just wondering if Pontiac Gtp injectors would be a plug and play install or if anyone had any suggestions on injectors I could pull at my local junk yard? The tuner thinks says the factor ones might be fine at only 6psi that I'm running but if possible I'd like to get something a Little better on my junk yard budget like the rest of the build. Any thoughts?
Re: GTP Injectors?
Wednesday, February 17, 2016 1:56 PM
You have to make sure the injector angle and spray pattern is correct for your engine. People get away with wrong spray patterns but it's not ideal.
