I just got done putting a new turbo setup on. It first takes a couple of tries to get it started it backfires a couple of times and then when it does stay running if u hit the gas to fast it will die.im running the gm reflash with the injectors and tmap.Could this promblem come from a bad wiring job on the tmap i got the diagram off of here but not sure what way the wires went if the clip was upside down or not cause acording to the picture the stock ones were upside down so i figured that one would be.I never had this promblem with the last setup i had so i dont know what the promblem is
How does it idle? Does it idle super rich and rough? If so Id say you got the map sensor wrong. Wheat sensor did you use? The one the directly plus in the one you need to swap pig tails? What size injectors and what did you change the injector constant to?
12.6 @ 114.6 MPH
Sounds like fuel relearn, should not do it that long. Check tmap wiring
I believe he is talking about an 04. Which on the eco re-flash can not be edited at all with hptuners.
yes the cars an 04 2.2 eco the ecu was used bought from here about a year ago just put it on.it came with the injector the only extra i had to buy was the tmap and the pigtail.i did do the passlock relearn though after ten min it started ..
so maybe ill try to do the relearn again .maybe it will help make it stop running so rough and stop dying
