Any one hooked up a boost controller to the actuator for the supercharger? I know it will not "give" you more boost but I have a smaller then stock pulley and was thinking it could probly regulate how high the boost would get. Ex say I'm at 10psi but would rather be at 8. Hope I'm not sounding like an idiot. If I see this right it should be just like a wastegate. Correct?
A new pulley is not much more money. What's wrong with just buying a larger pulley?
its an old concept. time for something new to take the reigns. - Z yaaaa
Nothing I was just using that as an example. I have like 3 boost controllers here.like if someone else was to drive your car you can lower the boost.I was just wandering. Not that I had any plans to do so
FYI with a 2.8 pulley and the bypass all the way open you will still make 5 psi. idk about any other pulley.
Sponsored by:
Kronos Performance
If i understand the cobalt ss/sc system correctly, it electronically controls the bypass valve to bleed of boost if commanded. its basically just a flapper. however, it cannot be used to increase boost without using a smaller pulley. Also, keep in mind that it remains more or less open at low throttle position so that the car remains somewhat fuel efficient.
Leafy, that's good to know, so with the smaller pully and the valve all the way open it makes the same boost as the stock pulley?
Old school, I have the m45 and its vacume operated. And looks just like a wastegate actuator that's what gave me the idea. I know it will not create anymore boost then the pulley will let it.
why would you want less boost?
have you read the
RULES yet?
my carDomain updated 6/11/10 Forged and Supercharged
Nate (THE NASTY ONE) wrote:Leafy, that's good to know, so with the smaller pully and the valve all the way open it makes the same boost as the stock pulley?
Even with a 2.4" pulley and the M45, if the bypass is open you will see no positive manifold pressure. If you want to regulate your pressure just dont go WOT.
Dragracemyz24 wrote:s1lver_N1p (forum_Naz1) wrote:why would you want less boost?
X2?
can any of you read? so if anyone else (the wife) was to drive the damn car and you dont want it to be full boost then you can control it! why is it sooo damn hard to just answer the question at hand?@!#$! you people are really killing me. and i allready stated that i wasnt goin to do this i was just wandering. why wouldnt it work then tell me that? why dont one of you turbo guys by my profec b so i will stop trying to think of ways to use it even though i wouldnt be using it anyways
Edited 1 time(s). Last edited Monday, September 27, 2010 5:20 PM
zzperformance.com has a boost controler for the eaton superchargers
JBO since July 30, 2001
i have a greddy profec b. i just wanted to know if anyone else has tried it
I like the idea of a lower boost setting for those that don't need to romp on your car when driving it or when you shouldn't be, lol, that is mainly why my car will have 2 levels of boost when its boosted, but no idea if it would work on the M45, never thought about it. But I agree a cool idea man.
Nate (THE NASTY ONE) wrote:can any of you read? so if anyone else (the wife) was to drive the damn car and you dont want it to be full boost then you can control it! why is it sooo damn hard to just answer the question at hand?@!#$! you people are really killing me. and i already stated that i wasnt goin to do this i was just wandering. why wouldnt it work then tell me that? why dont one of you turbo guys by my profec b so i will stop trying to think of ways to use it even though i wouldnt be using it anyways
at what point does anyone driving realize they don't need to be WOT?
have you read the
RULES yet?
This post was not intended on starting a bitch fight but it seems that its all it will be. So I'm goin to hook the profect up and tell you guys if it works.
Thanx scorp
I know it sounds kind of odd, but I have two different settings for my turbo because I like the feeling of "flooring it." I understand that I can leave it on high boost and not floor it, but I guess I don't have enough self-restraint to not go WOT. I know I am not the only one ever who thinks this way, lol.
Wagonwes wrote:I know it sounds kind of odd, but I have two different settings for my turbo because I like the feeling of "flooring it." I understand that I can leave it on high boost and not floor it, but I guess I don't have enough self-restraint to not go WOT. I know I am not the only one ever who thinks this way, lol.
Along with the unintended reflex to floor it when you panic.
the idea you have would be ideal for gear limiting boost. like say m62 situation: 1st gear limited to 5 psi then 2nd shoot up to 12psi and 3rd gear 16psi from a 2.8" pulley on an LD9. Ive been pondering this idea and how to get it to work......
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
With the greedy joint if it works. When going into second just hit the button for the high boost setting. That's what I was doing when the car was running the turbo.
