anyone know the diameter of a stock LD9 crank pulley?
I know a 10% overdrive pulley is 6.9" does that mean that a stock would be 10% smaller? so -0.69" which would put it about 6.2? this sound right?
anyone got the actual measurement?
well yeah, if its 10% overdriven then you take away the 10% and that gives you the stock size.
Check with MD LD9 I know he knows for sure.
I plan on sending my RaceTech crank pulley to MD-LD9 so he can give me an exact measurement. It is supposed to be 10% overdriven, and I am pretty sure it is. I see 6 psi to 4500 and 10 psi @ 7k
Jason
99 Z24 Supercharged
157hp/171tq - NA
LD9 for Life
You want to the top of the teeth, or to the middle of the teeth?
-MD- LD9 wrote:You want to the top of the teeth, or to the middle of the teeth?
I want however they measure pulleys.... I just need to find the ratio between 2 pulleys...
i need to know how fast an accessory is driven compared to crank speed.
i have a 2.5" supercharger pulley... and need to know how big the crank pulley is so i can calculate the drive ratio to figure out the rpm of the supercharger.
so whatever measurement they use to claim a 2.5" SC pulley.... i need that same measurement on the crank pulley.
And i guess while i got you... I understand you make crank pulleys.... do you sell oversized/overdrive crank pulleys? I see you have stock size lightweight ones.... but got anything light weight and overdriven?
I think your almost at the end of what that m45 can do
Edited 1 time(s). Last edited Friday, March 28, 2008 4:18 PM
all i know is this, my OE pulley fit in the race tec one, like the HO pulley fits inside the LD9 one.
Chris
'02 Z-24 Supercharged
ken soggs wrote:-MD- LD9 wrote:You want to the top of the teeth, or to the middle of the teeth?
I guess they measure to the middle of the pulley grooves. I'll post later on that dimension.
I do not sell anything but stock diameter at this time.
Sorry been stuck at work. I'll PM you your dimension.
6.406" to the top of the pulley grooves.
6.284" to the middle of the pulley grooves.
