cobalt green tops? - Boost Forum
cobalt green tops?
Tuesday, August 21, 2007 8:40 PM
Ok i got a set of cobalt ss green tops..do i need the injector harness as well to run them on my 03 eco? or is it plug and play?
Re: cobalt green tops?
Tuesday, August 21, 2007 10:04 PM
Hmm, cobalt green tops? The only green tops i know are the Bosch Green tops and they are 42lb/440cc... If they are the Bosch ones, you can just buy a set of Bosch connectors...
My CarDomain!!! --- http://www.cardomain.com/ride/2543660
Tuesday, August 21, 2007 10:14 PM
the green injectors came out of the LSJ motor. they will work... but you'll need to change your injector constant in your tune. I plugged mine directly into my 2.2 L61 harness.
Desert Tuners
Wednesday, August 22, 2007 6:30 AM
^^Thats all i needed..thanks..phil
Wednesday, August 22, 2007 9:20 AM
am I correct in saying the LSJ injectors can also be used on the 2.4? would I need to change my injector constant to make them work?
Wednesday, August 22, 2007 7:18 PM
... HMmmm who with a LD9 is using LSJ injectors..........................?
look around. lots of people have them. LIKE ME. plug and play, as said, change the injector constant . there 36#
Chris
'02 Z-24 Supercharged
