I think i need spacers, but what not 100% sure. If so, anyone have a part number?
I know the injectors I put in didn't fit perfect. So instead of getting spacers we just shaved off some material from where the rail meets the head. This brought the injector down just enoguh so they fit great!
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
ECOTEC wrote:I know the injectors I put in didn't fit perfect. So instead of getting spacers we just shaved off some material from where the rail meets the head. This brought the injector down just enoguh so they fit great!
What injectors did you use?
I have the LSJ injectors in my 05 and didnt have to modify anything, just bolt them on..
You talking about the little grey things that go on the end of the injectors?, if the car is an 03+ it should already have those
For a correct fit without shaving down the mounting taps, you would have to get the 02 ecotec fuel rail and hard lines. If you look at the LSJ injectors next to the stock ones, you will see the stock ones are slightly longer. If you cant get yourself a set of the GMPP S/C kit injectors they will swap right in. Some people say you will need spacers.... i tried the stock 03+,02 and the stock LSJ spacers, i had a strong fuel smell at WOT with anything i tried. I swapped in the GMPP injectors and that fixed it.
