ok so basicly i am about to buy a used turbo kit off a friend i know who has a cavy and i am kinda scared and anxious to do it....
1st- how easy is it toblow my motor ? how hard is it to do everything (oil lines etc) do i need to change my ecu or will i just be running funny thats it for no thanks
www.howstuffworks.com
read read read, this site has lots of info, and you will be reading for days.
ethan silovsky wrote:how easy is it toblow my motor ?
dont think you are ready for a turbo yet, you should read as much info on your engine as possible....specs, weaknesses, strengths. etc
PROUD MEMBER OF JBOK.
How hard is it to blow your motor?? Hmm... depends on the motor, but if you're turboing it, definite and imminent(sp?).
check the turbo for shaft play and the lines are in good shape as well as the charge pipes other than that theres not much to worry about
