Replacing Vaccum Actuator On 2.4 GM SC Instructions? - Boost Forum
Thursday, April 05, 2007 1:07 PM
I have ordered a new actuator for my 2.4 SC and have been reading that it is crucial to get it calibrated right. Is there any info on how to do this before I screw it up? Can I just mark it some how, I have not found any information on this topic.
I am currently only seeing 4-5 psi on the 2.6 inch pulley so I hope this helps.
Chris
2.3-2.4 HO ADAPTER FLANGES 65$ shipped, Check GP Forum!
Re: Replacing Vaccum Actuator On 2.4 GM SC Instructions?
Thursday, April 05, 2007 3:20 PM
i'm also wondering about this issue. hopefully someone can shed some light.
supercharged 2.4L alero
www.cardomain.com/ride/2168613
Thursday, April 05, 2007 8:04 PM
They're set from the factory, big "do not adjust" sticker on 'em...it probably refers to the settings of fully opened and closed, perhaps spring tension as well. There is a "stop screw" that the rod contacts when you take vacuum away and it shuts the bypass valve. If you can get your hands on a vacuum pump, you can use that to test whether or not it's moving properly using a light and a mirror. If you can't use a vacuum pump, I guess you could just unplug the hose at the throttle body and watch for the rod to move. If it's not closing the bypass valve fully, it may explain the lower boost levels.
It seems there are quite a few of us out there now who are having this issue, their units are getting older and wearing out and not performing as well as we're used to.
Sucks
14.330 @ 96.37mph
Friday, April 06, 2007 5:24 AM
mine never performed good, lol. I have never seen over 5 psi, for that much money 5 psi is a joke.
Friday, April 06, 2007 1:06 PM
Don't judge by what your gauge tells you, judge by how many kpa the ECU sees from the MAP (if you haven't already)
14.330 @ 96.37mph
Friday, April 06, 2007 7:02 PM
Chris Fontana wrote:I have ordered a new actuator for my 2.4 SC and have been reading that it is crucial to get it calibrated right. Is there any info on how to do this before I screw it up? Can I just mark it some how, I have not found any information on this topic.
Chris
Hey Chris,
Where did you order the actuator and under what part number?
Also, with all the S/C they rebuild/port, couldn't Stiegemeier Porting give advice for what you are asking?
Just a thought
Friday, April 06, 2007 8:23 PM
i purchased mine off of gmpartsdirect.com. i can't think of the part number right now, but i can get it for you tomorrow when i get to work.
Friday, April 06, 2007 8:28 PM
88960487
Thats the number I paid 115 on GMPD but hasnt gotten here yet. I know not to trust the guage but damn I went 15.3 with the stupid thing I have to get more power, lol.
Friday, April 06, 2007 9:24 PM
Thanks for the info.
Sunday, April 08, 2007 12:21 AM
Chris, keep us updated when you get it. I think alot of us will have to go this route.
Monday, April 09, 2007 2:24 PM
I will let everyone know, how hard can it be to replace. I assume I can mark it and go from there I will definantly get some pics up. I hope this works, my car is so damn slow. Anyone know how long it takes GMPD to ship stuff?
