Saab low pressure turbo? - Boost Forum
Sunday, November 19, 2006 7:58 PM
I called a local junk yard about a price on a Saab turbo off of 2003 9-3. The turbo was listed as low pressure. What does this mean?
Re: Saab low pressure turbo?
Sunday, November 19, 2006 8:57 PM
It's not meant to really increase the power output of the engine as much as smooth out the powerband. The turbo kicks in at a mere 1950 to 2200 rpm (depending on model), and maintains an almost flat torque curve at 155 to 170-ish lbs/ft all the way up to 5500rpm or so.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Sunday, November 19, 2006 9:55 PM
So when I am looking around for the turbos, would it be better to buy a low or high pressure turbo?
Sunday, November 19, 2006 10:27 PM
The low pressure garret saab turbo engine is rated at 175 hp.
The high output mitsu turbo engine is rated at 210 hp.
The low pressure turbo has a noticibly smaller compressor housing.
