It dosen't say what brand it is, I would like a better pic of the compressor housing. If it says "xs power" on the turbo, don't get it. Thats a really cheap price though, I would be careful. There was an ebay company called "ssautochrome" that sold turbos for cheap prices, but they fell apart.
spend some money get a real turbo
www.atpturbo.com
decent prices too
LE61T PTE6262 Powered
Is this turbo a good size for the 2.4L LD9 engine?
I know a lot of people here use a t3 super 60 on there 2.4L..
I have a t3 turbo turbine .48, compressor .42 and want to go with a bigger turbo but don't know wich size to choose.
If you want to figure it out properly without people internet-building your car improperly, draw up a few compressor maps and see what your needs are and go from there.
Best way to do it.
-Chris-
-Sweetness-
-Turbocharged-
besides on that page it says it will work with an internal wastegate only so you can forget about that new external wastegate you just bought
14.425 @ 97.833 mph stock + GMPP s/c on drag radials.
QBE (The Boosted One) wrote:spend some money get a real turbo
www.atpturbo.com
decent prices too
Ball bearing turbos are the way to go. Too bad I bought my GT30R from ATP turbo and never got a chance to install it
before the BUILT motor started knocking, durring the break in none the less. Machine shop better fix it....
Be weary of cheap turbo's they don't last very long. Your talking about something that spins over 150,000 RPM and gets very very hot.
22 miles per gallon and dropping fast...
if it doesn't say garret or turbonetics on it I won't buy it.
**changes are here**
Im currently useing the ss autocrome t3 and have been for almost a year and have never had a problem with it. pushing 19lbs fine
DRIVE HARD OR DONT DRIVE AT ALL!!!
i have used crappy turbos on a couple of my kits i mean i know they are @!#$ but i havent had any of them blow up. But currently im using a crappy one for my new kit for pure fitment issues then im going to swap out to a garret ball bearing turbo after the rebuild.
*2012 mazdaspeed3*
DO NOT BUY THAT!!! the turbo you want must say Garrett on it, period.. trust only the best when it takes so much planning and time.. and in a whole kit what is the difference in 200-300 bucks.. I would trust a used one from a 1986-90(?) 300zx over that. They are 0.63 exhaust and 0.60 compressor.. unsure of trim.. my 0.02
aww c'mon! My warner-ishi IHI turbo is cool too!
yeah my BorgWarner / IHI turbo is kickin some serious butt. *laughs*
-Chris-
-Sweetness-
-Turbocharged-
my name is Garrett too, lol, Airearch is good, BorgWarner / IHI, turbonetics.. anything fancy will do
