were to run oil feed line??? - Boost Forum
Sunday, August 27, 2006 7:07 PM
i searched and cant pull nothing up, can someone help me out.
Re: were to run oil feed line???
Sunday, August 27, 2006 7:21 PM
by the way i got a 98 2.4 and it would also be helpfull if someone had pics of there line set up
Monday, August 28, 2006 11:44 AM
what do you mean? you run it from the cam tower to turbo.
explain
Monday, August 28, 2006 2:07 PM
^^ What he said. Just put in a 'T' fitting at the oil pressure sending unit (located between the cam towers on the drivers side) and run the feed line from there to the oil inlet side of the turbo. Most recommend an oil feed restrictor to help save you turbo oil seals....
Wednesday, August 30, 2006 8:05 AM
thank you just the info i needed
