Is there any one that would be interested in a two stage boost controller that would cost about $50. It would allow you to use a switch in the car to toggle between wastegate spring pressure and a higher boost level that you could set yourself. I'm not looking for money I just want to see if people would be interested before I spend an hour typing instructions with part numbers.
So if your interested post here and if there is a few people that would like to see it I can start work on it.
............super 60 on its way
interested... send me e-mail
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
Alright I guess I will get started with it. Check back in a few days I should have them up.
I'd be interested also. I'll check back.
_________________________________________
450WHP Turbo Ecotec swap in the works...
