going to advanced auto tuesday and picking up about 10 bottles or so of heet stuff since i used it tonight and it works GREAT. I put in 2 bottles in a gallon jug and filled the rest with water, whats the max number of heet bottles i can add in a gallon jug so its on the borderline of too much meth cause i heard too much meth will eat the charger up so i wanna get the most outta the injection as i can. thanks guys.
heet = 100% (99.9
methanol.
1995 Cavalier W/2k1 Engine
you could just empty 2 of them then fill them up with the water and fill the jug
i mix mine 50/50 and carry a couple 2l pop bottles with me in the trunk
methanol will not eat the teflon on the rotors
so just do what i been doing 2 bottles and the rest of the gallon water? what would 3 do? any benifit you think? thanks.
LAFNGAS wrote:you could just empty 2 of them then fill them up with the water and fill the jug
He mixes it 50/50, balance the amount of water and methanol.
http://www.cardomain.com/ride/857357
make sure it is distilled water.
Jake wrote:make sure it is distilled water.
what if its not and does anyone here use just regular water cause i used reg water for this time and everythings fine, i used a whole 2 qrt tank of the mixture.
there is more crap/sediments in tap water compared to distilled water.
just pick some up at a grocery store for 1$.
tap water will clog up the filter and put deposites in the pump and fittings
i wouldnt use tap water unless its a last resort
[quote=97cavie24ls(JDM&00s/c sedans™)]tap water will clog up the filter and put deposites in the pump and fittings
x2
Just boil tap water and see what you got left in the pan.
isnt heet post to remove water? and why are you guys adding water back into the system?
Opening Soon Kustom J's
well right now im using 2 bottles of heet with the rest distilled water and its working noticibly better than windsheild fluid that was only 8% meth that i could find lol. so 12 bottles of heet and 6 gallons of distilled water = 18 bucks and a few fillups for the future
i think i might add in 3 bottles of heet to the next fill to see what happens, this last time i mixed 2 bottles and the rest water in a gallon jug, should only filled half way up but i wasnt thinking so next time im gonna fill half gallon with distilled and add in 3 bottles, that be alright you guys think?
yep, 3 bottles will be ok. just experiment with what your car likes.
