How to use gm 2.0ls/c injectors in a LD9. - Boost Forum
Monday, August 07, 2006 8:48 AM
Since my injectors are at 100% duty cycle, i was able to snag some 2.0 ion s/c 36lbs injectors off my friend as he upgraded to the gm stage 2 kit.
The majory problem with these injectors is that they are 1/4" shorter then stock injector height .
So do compensate for that, i redrilled the holes 1/4 higher and then went ahead and 'machined' (with dremel) out the half circle to match the stock mounting surface.
To use the stock gm injector clips, I had to cut a groove on the injector. I just used a hack saw (very carefully) to connnect to the two grooves.
After that, it was just reinstalling everything. They used the same injector clips, and everything fit perfectly.
The only problem i'm having is the my oring on the end of the fuel rail is leaking, and i have to wait for the autoparts store to open to pick up a new one.
Hope that helps. It gives an option vs using spacers like 97cavie24ls did.
Nate
1995 Cavalier W/2k1 Engine
Re: How to use gm 2.0ls/c injectors in a LD9.
Monday, August 07, 2006 11:46 AM
yeah i dont have any clips on mine , they are kinda wedged
since the plastic spacer kinda thing keeps the injectors from falling in the head
when i was playing with the stock rail i didnt think there was enough meat to to make um work , and im using a venom rail since it was easier to drill and tap for the fuel pressure gauge
with the standard gm s/c program im runing mid 11's for afr , at 30 psi base fuel pressure
forgot to add , nice work and enjoy the extra room with the larger injectors
Edited 1 time(s). Last edited Monday, August 07, 2006 11:47 AM
Monday, August 07, 2006 12:01 PM
Great work man, Now give us some AF numbers and such
Monday, August 07, 2006 12:16 PM
So can the reflash manage these injectors? If so I may do this setup with mine because I have access to a machine shop...hehe
~Boost. Its what's for dinner!~
Monday, August 07, 2006 12:51 PM
Timothy Pietraallo wrote:So can the reflash manage these injectors? If so I may do this setup with mine because I have access to a machine shop...hehe
[quote=97cavie24ls(JDM&00s/c sedans™)]
read much ??
Monday, August 07, 2006 2:07 PM
Use the one of the orings off your old injectors. I had the same problem when I tapped my rail. I think its the bottom oring that will work.
Monday, August 07, 2006 3:33 PM
mm.. Ok. maybe u guys can help me with this. The 'in' line on the fuel rail uses a plastic/nylon oring. Its hard and suppose to be a for fuel. HOWEVEr, it leaks now and no autopart store carries them. Its a holiday up here so no dealership is open to see if they have what i'm looking for. I have a regular boss rubber oring that fits in there and doesn't leak at all. But its not made to last long in fuel.
Now my question is, is there more then 1 oring on the 'in' line of the fuel rail? and i'm lost the other one? or has anybody had to replace that one, and noticed it was a hard white looking plastic like oring not just a rubber one.
So so far, i haven't even started the car yet. Will wait to see if gm has one(if they can figure out what i'm talking about of the phone). I don't have a gm manual to even look at the diagram to pull off the part number. Would held. Would be under fuel rail assembly in engine part.
Nate
Monday, August 07, 2006 6:48 PM
Thanks I think I just read that wrong and thats why I missed it. I will be attempting this soon I think. I will post my results.
Monday, August 07, 2006 7:25 PM
When I stripped my rail to added a fuel pressure gauge I also noticed the white hard oring. When I reassembled the rail, it leaked from that spot. Being late at night the only thing I had was the orings off my old injectors. I used the bottom oring and it hasn't leaked since.
Monday, August 07, 2006 8:43 PM
SPDDMON wrote:When I stripped my rail to added a fuel pressure gauge I also noticed the white hard oring. When I reassembled the rail, it leaked from that spot. Being late at night the only thing I had was the orings off my old injectors. I used the bottom oring and it hasn't leaked since.
spddmon,
I get where u going. And ur right, they do fit perfect. The only thing that bugs me is that i'm not sure if those injector orings are fuel rated. Would make sense, but would suck to have it blow out too. Its a temp fix, for sure. But just hope gm has some fuel orings kicking around. Just seeing if anybody else has had any luck.
mm..how long have u had the rubber oring in there?
Nate
Tuesday, August 08, 2006 3:37 PM
Its been in there for 2 months, and they are fuel rated otherwise they wouldn't be on the injectors.
Tuesday, August 08, 2006 11:53 PM
Wednesday, August 09, 2006 8:50 AM
I believe I did the same thing as SpdDmon....... its been so long I cant remember.......
How big are the 2.0S/C injectors?
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Wednesday, August 09, 2006 8:53 AM
SpeedRacerZ wrote:I believe I did the same thing as SpdDmon....... its been so long I cant remember.......
36lb i think
Wednesday, August 16, 2006 4:48 PM
Yup. 2.0 injectors are 36lb or 378cc.
For that matter, i'm going up to 440ccs b/c i can with hpt Going to sell these injectors. Anybody know anybody intereted? Could sell it with modified fuel rail too. Want $200 us for them or 225 rail.
Nate
Wednesday, August 16, 2006 9:11 PM
Well I just got a set of injectors from a cobalt ss supercharged and I have my rail. I just need to take the time to do it now. I will post my results when I finish.
Friday, September 01, 2006 6:38 AM
hey hows the car run with the injectors? i can get some from my boy locally and wondering if i should since i need larger ones when i get tuned soon? thanks.
Friday, September 01, 2006 3:22 PM
they work very well.
Friday, September 01, 2006 3:45 PM
ive been very happy with mine
Saturday, September 02, 2006 10:40 AM
you still have those other injectors Eric?
Saturday, September 02, 2006 1:23 PM
yup still got um
Saturday, September 02, 2006 8:24 PM
did the rail mount up perfectly after you "machined" the 1/4" higher holes or did it rub again the engine?
Saturday, September 02, 2006 8:25 PM
i tried to post the second photo in the first post of him drilling out the new holes.
Saturday, September 02, 2006 10:45 PM
BOOSTED (The Untuned Demon) wrote:did the rail mount up perfectly after you "machined" the 1/4" higher holes or did it rub again the engine?
Nope... after i machined them.. i ovaled out the bolt hole like in the pic. Bolts up fine, no rubbing. Pretty damn close to not fitting..ie..injector hitting the fuel return line. But just clears everything. I actually got the 1/4" difference from GM. When they sell the eco charger, they note the difference in injector lengths.
Nate
Sunday, September 03, 2006 8:31 AM
hey nate, got my spare 2.4 rail taken off my other car today and wondering where did you measure 1/4 inch higher for the new mounting holes, from the edge or center of the stock holes? thanks
