a few turbo problems, Need the orgs help - Boost Forum
Tuesday, July 25, 2006 5:19 PM
I am nearing compleation of my project, but as with any custom fab project Im having a few problems. for starters my brother striped a thread in the engine on the exhaust manifold. and Ive been wondering a few things. what is the best way to fix this? also do you guys know If I have to can I drive the car with the one exhaust bolt off? its all the way on the end.
thanks guys.
"Kick azz is my boost hero!!! "
Re: a few turbo problems, Need the orgs help
Tuesday, July 25, 2006 5:59 PM
I highly recomment a tread saver kit from timesert. Their kit may be a little expensive, i.e. like $70 but those threads will almost never strip again. The replacement is made from carbon steel and is very strong, and the install process needs no power tools.
All done by hand.
Tuesday, July 25, 2006 6:10 PM
Im guessing it is just a replacement screw?
Tuesday, July 25, 2006 8:32 PM
no its a new threaded sleeve that taps into the hole with threads for the bolt if im not mistaken.
Tuesday, July 25, 2006 9:56 PM
Either that or replace your head lol
<img src="http://memimage.cardomain.net/member_images/3/web/831000-831999/831395_11_full.jpg">
Tuesday, July 25, 2006 9:58 PM
SpyderWizard wrote:no its a new threaded sleeve that taps into the hole with threads for the bolt if im not mistaken.
I was told I needed a dye
Tuesday, July 25, 2006 10:17 PM
Yea you will have to make the hole bigger so you can tap it for the sleeve, i recommend putting threadlock on the sleeve, i have a 94 escort that had a heli-coil in it... everytime i replaced the plugs the damn thing would come out on the plug.
Wednesday, July 26, 2006 8:54 AM
i would try to use a heli coil, you can pick up the kit with the tool for like $20-30 at a local hardware store
Wednesday, July 26, 2006 1:56 PM
It's a die, not a dye, a la tap & die set. You can TRY to chase the threads with a die, it might work out for you.
14.330 @ 96.37mph
Wednesday, July 26, 2006 2:52 PM
thanks guys
Wednesday, July 26, 2006 2:53 PM
now I have to ask what would happen if I were to try and drive it with everything eles tigtend down. would it still blow the gasket?
Wednesday, July 26, 2006 3:12 PM
Probably... Even without boost it wouldnt hold for long.
