2.4L turbo oil return line question... - Boost Forum
Tuesday, July 11, 2006 4:58 PM
what are u guys running for oil return when it comes to the 2.4 and being turbo... looking for different options.
running straight to the oil pan isnt an option i want to take due to factors that lead to blowing turbo seals.
gimme some options guys.
BeardLife / Club Awesome Reject Blog
Re: 2.4L turbo oil return line question...
Tuesday, July 11, 2006 5:00 PM
Why would running straight into the oil pan cause your seals to blow?
Tuesday, July 11, 2006 5:03 PM
rumor has it the oil pan in a 2.4 is full at all times. causing problems with the oil return line.
Tuesday, July 11, 2006 5:19 PM
There is an obvious line inside the pan when you drop it, its not completely full all the time.
Tuesday, July 11, 2006 5:58 PM
On the dip stick the full line is at the same level where the bottom of the block meets the top of the oil pan, meaning, when the motor is not running the oil level should be dead even with the top of the pan / bottom of the engine block.
There seems to be a staggering amount of turbos blowing seals on 2.4's where the oil return is plum directly to the oil pan. Every single turbo 2.4 guy here in Mi. that i know (probably 10 of them) that is running the return to the oil pan have blown the seals on their turbo at least once, some twice.
Another factor i think is contributing is the lack of a functioning PCV system on most 2.4 turbo systems.
All of this just raises a suspicion, maybe its just a coincidence, i don't have a sure answer.
Shifted, did you already blow the seals on a turbo as well?
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Tuesday, July 11, 2006 6:32 PM
arent there 2 good oil taps and 2 water taps? are both taps for each trying to flow out? i see them from my 2.3 why not hook the return line to the cam gear housing?
Tuesday, July 11, 2006 6:37 PM
No, didn't blow my seals.
I think the cause is more cold oil pressure on the feed side rather than the return. Cold pressures are upwards of 60psi.
Tuesday, July 11, 2006 6:39 PM
ok then. throw some things at me that would help reduce or eliminate blowing turbo seals. i already have the PCV situation under control.
what else could help?
Tuesday, July 11, 2006 6:45 PM
Shifted wrote:No, didn't blow my seals.
Or close to 90 psi on the HO oil pump conversion when cold......
Tuesday, July 11, 2006 6:50 PM
i went straight into my oil pan with a 3/4" fitting , and kept it as high as i oculd
never had any problems with seals
ive seen factroy turbo cars with the drain in the bottom
Wednesday, July 12, 2006 12:56 PM
I have about 80 psi of oil pressure everyday when i start my car and have never blown seals in my turbo. I use a -3 feed line with no restrictor.
Wednesday, July 12, 2006 1:09 PM
I use a -3 an pressure hose with no restrictor and a 5/8" return and have never had a problem with mine.
Wednesday, July 12, 2006 3:30 PM
I think most of the problem is the little PCV hole in the head. If people turbo their car with a 2.4 intake mani, your basically pushing 8-whatever psi into the bottom end of your motor, which would want to push oil back up the drain line, which would blow their seal. Easiest effective way is either plug the hole, not advisable but would be better than pressurizing it, or 2.3 manifold swap, drill and tap manifold, screw in a barb fitting, catch can to catch oil, then run it to the intake "sucking" side of the turbo. I think as long as you keep it up high enough, and use larger than 1/2 inch fitting and lines, it will be fine. Also, look where you tap into the pan, because some places in the pan, the balance shaft assembly is close to the wall of the pan, and if you thread in a fitting, it will either block the fitting or get really close to blocking it from draining, so when you drill and tap it off of the car, put in on the block, look through the hole and check to make sure nothing is blocking it.
Wednesday, July 12, 2006 4:59 PM
