did a search didnt find the info i needed though, looking to put out about 7-8 psi will this turbo do the trick, im still pretty new to this and im trying to peice together a kit to save myself from paying $3000+ for a built kit i found a 00' 9-3 saab turbo used for like $150 seemed like a good deal but will it do what i want it to if tuned correctly without doing internals?
I believe the SAAB 9-3 turbo/manifold fits on a ecotec, the turbo would be an appropriate size, for lower HP numbers,
The 00' 9-3 turbo doesn't fit anything J related.
You would need the correct flange for the manifold. (for the saab turbo)
what manifolds do fit the 3rd gens? or is it a custom application?
john engvik wrote:what manifolds do fit the 3rd gens? or is it a custom application?
the 03+ saab 9-3's with the ecotec engine. (Not ecopower)
