Which Alcohol for alky injection? - Boost Forum
Thursday, June 22, 2006 8:58 AM
Hey guys,
well i can buy bulk through work. We can get isopropy alcohol at 99%..is that the stuff thats in heed etc.?
Thanks
Nate
1995 Cavalier W/2k1 Engine
Re: Which Alcohol for alky injection?
Thursday, June 22, 2006 10:00 AM
you mean HEET. which is 99% methonal.
i havent used alcohol, so i have no input.
Thursday, June 22, 2006 2:38 PM
im using the boost juice from snow performance, pretty pricey but seems to be working ok
Thursday, June 22, 2006 3:19 PM
i use pure methanol as i get it from work and mix it 50/50 for just bombing around but 100% in a cooler when i hit the track
Thursday, June 22, 2006 7:18 PM
K. Came across this while doing MSDS sheets for work.
Anybody try methyl hydrate yet? I'm looking for options b/c i haven't found a place that sells bulk methanol here where i live (Vancouver Canada) and i sucks paying $3 for one little bottle of heed.
http://www.recochem.com/english/products/faqs.html
Group II: Alcohols and Relative Solvents
Methyl Hydrate
Is there a difference between Methyl Hydrate, Methanol, and Wood Alcohol?
Answer: There is no difference between these products; it is just a different name for the same thing.
Is there a difference between Denatured Alcohol and Methanol, or are they the same?
Answer: They are not the same, but in most workshop applications either one can be used. Otherwise, Denatured Alcohol is an ethanol-based product and is considered less toxic than Methanol. Check to see if the manufacturer specifies one in particular and follow the recommendation.
Where can I use Methyl Hydrate?
Answer: Methyl Hydrate, also known as Methanol and Wood Alcohol, is used as a fondue fuel, shellac thinner, gas line antifreeze, and, when mixed with water, as a powerful window cleaner.
Thursday, June 22, 2006 7:25 PM
my 5 gallon pails say methanol and methyl hydrate on them and i use it with no ill effects
Thursday, June 22, 2006 7:33 PM
Looking at the MSDS sheet it says 100% methanol. Heres a link to the consumers log in, have a look, i made up a username and password for everybody.
Your login information is as follows:
User Name: CarGu1
Password: jbody
https://nt9.magma.ca/recochem/consumers/consumerLogin.asp
Lafngas,
so the same pale says methonal and methyl hydrate?
Friday, June 23, 2006 12:12 AM
one of mine says methanol but the other says methyl hydrate but its the same stuff
