where can I get GM S/C installed on my 99 Z - Boost Forum
Monday, June 05, 2006 8:23 PM
I have been wanting to get one installed I live in Arlington Texas and do not know where I can get a GM Super charger installed. Please Help
Re: where can I get GM S/C installed on my 99 Z
My Car is a 99 2.4L
Monday, June 05, 2006 8:30 PM
do you have the reflash?
64 Cutlass Convert.
72 442 11 sec., National Winner, Show car
99 Alero GL 2.4, 04 Olds Nationals Winner
Alero Chapter of the OCA car club President
Monday, June 05, 2006 8:33 PM
it is a 99............so the reflash wont work.....you will need to get bigger injectors and a fmu....most liekly a dealer wont touch it.
best bet is to find someone local to help ya.....preferably w/ experience
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
Monday, June 05, 2006 9:05 PM
99 should be able to use the s/c kit injectors , all the 99's ive seen used the same injectors as the 00-02
Monday, June 05, 2006 9:25 PM
per Lenko, the casting on the 99-02 head is 779, so it should be the same. the 98 and prior year heads are a different casting number.
Desert Tuners
Monday, June 05, 2006 9:51 PM
The 99 and 2000 engines are identical, save the first O2 sensor (1 wire on 99, 2 wires on 00). Everything else is the same. BTW, no one has ever seen EGR on a 99... so for now that remains a nasty rumour.
There are pretty comprehensive directions that come with the GM Supercharger kit... I'd say grab a couple of buddies and some tools and do it yourself
Heck... go to a wrecker... find a 2000, 2001 or 2002.... with the same drivetrain as yours.... swap everything.... body harness, dash harness, cluster, BCM, brake module, etc.... and you have a 2000 in a 1999 shell. (I did this to my white 'vert, then sold it.... the owner is on here... has the GM S/C now... worked perfectly)
Tuesday, June 06, 2006 2:29 PM
Lenko means the knock sensor......and he is correct, other than that, same engine. No egr.
Tuesday, June 06, 2006 3:39 PM
No, I mean the first O2 sensor. The knock sensor changed for the 99 model year.
Tuesday, June 06, 2006 4:57 PM
hmmm? I never knew that the 02 sensors changed, but I did know the knock sensors changed in 99, sorry bout that, I thought you were talking about for the 99 year.
Tuesday, June 06, 2006 11:01 PM
Nope, he's right. I'm looking at the O2 sensors from the '99 and the '00 right now. the '99 has one wire and the 'oo has 2 wires. I was gonna use the one from the '00 motor I had when I installed my header because it was practically brand new, but it has an extra wire :-)
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Wednesday, June 07, 2006 7:31 AM
Maximus Warrior wrote:I have been wanting to get one installed I live in Arlington Texas and do not know where I can get a GM Super charger installed. Please Help
Dude post this in the Texas Forum man. There are lots of use around the dallas area that would be willing to help you out. Just find out when people could come and help and pick a install day. Let me know if you need any help from me too.
Wednesday, June 07, 2006 7:33 AM
Do you already got the gm supercharger and all the parts for the install.
Wednesday, June 07, 2006 9:19 AM
No I do'nt have the parts yet. I was trying to make sure I could do it before I bought it
