What A/F numbers do you get with boost? - Boost Forum
Thursday, April 20, 2006 10:10 PM
Hey guys,
hooked up my plx m300 wideband o2 gauge/sensor. Works pretty slick. With a 2.7 pulley on hitting 6-8psi, at WOT is below 14.7 (richer). I think i was seeing anything from 11 to 12. Now, just curious to what others are seeing and with which pulley. Anybody max out their gm s/c injectors yet? And install new (bigger ones).
Nate
1995 Cavalier W/2k1 Engine
Re: What A/F numbers do you get with boost?
Friday, April 21, 2006 4:00 AM
those are good numbers for boost... but then again thats because of the GM reflash...
LE61T PTE6262 Powered
Sunday, April 23, 2006 9:25 AM
at 6psi boost i am seeing 12.0 at WOT and 14.4 when under no load.
Sunday, April 23, 2006 10:38 AM
I get high 11s at WOT.......and 14.4-15.2 at cruising speed and idle..
Car is for Sale!Supercharger kit is for sale!
Sunday, April 23, 2006 10:50 AM
Bobby(Blown&Pullied) wrote:I get high 11s at WOT.......and 14.4-15.2 at cruising speed and idle..
Thats about what I see. So are numbers that low under boost generally good?
Monday, April 24, 2006 9:20 PM
15.5-16 at cruise 14.5 or so at part throttle, 12's& 13's at moderate throttle low boost (to 5 psi or so) and right on down to 11 - 10.5 at wot past 10 psi.
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
Tuesday, April 25, 2006 9:43 AM
i was seeing low 13's at full throttle in all gears , im not sure what size pulley ive got
my s/c is 1 of the proto types GM had , and measured it against a 2.8 pulley , and mine is smaller than the 2.8 , but its not much smaller
i usually see 5-7 psi
ive got 36lb injectors now and i see low 12's , and sometimes 11's , depends if i have my alky on or off and how cold or hot it is out
Tuesday, April 25, 2006 9:45 AM
and forgot to mention
ive droped my fuel pressure from 50 at idle to 30
so ive got alot more room with them 36lb injectors
on the s/c kit injectors , i went up to 65psi , and still couldnt get out of the low 13's for afr
