boost octane question... - Boost Forum
Thursday, April 20, 2006 12:36 AM
here's a question for you boost guys. if i was to turbocharge my cavalier (2.2 eco) could i use a manual boost controller to put boost pressure to zero (o) psi. and assuming i could, could i use regular 87 octane instead of premium gas while at zero psi?
the reason i ask is bc soon enough i will have to choose between a s/c setup or a t/c setup. and if i CAN periodically use regular gas (ie. for long trips or such like) then i will go turbo, if not i would prefer the reliability of a s/c.
and please dont give me all that junk about "if youre boosting then why do you care about economy" i care about economy on long trips, im not rich-but unfortuneatly i am addicted to going fast. thanx in advance.
Re: boost octane question...
Thursday, April 20, 2006 5:14 AM
If you can't spend an extra $.25 a gallon ($4.00 per fill up or so), then you probably shouldn't be boost ing your car, since the maintainence costs will go way up as well.
Thursday, April 20, 2006 5:37 AM
I have run lower octane for long trips. I just don't rev the engine. I have had no knock this way. I do have lower compression. I'm not sure if a blown eco would knock in these conditions. I'm sure plumbing the intercooler would help a great deal.
You'll have to admit Mr.Shifted makes sense. However the GM charger kit seems to add little to no additional maintenance.
Thursday, April 20, 2006 6:50 AM
so far i have been running 100 octane for a few days.....i just got my setup up and running so i havent really put anything less than that in....i would go 93 if anything
Thursday, April 20, 2006 9:53 AM
ok. shifted, i know what you are saying and i completely agree, but the question was just that, a question. i know that a sc setup will be more reliable but for long trips i would like to know if i can use the lower grade fuel assuming im running 0 psi of boost. assuming that this is possible i would deal with the maintenance issues of the turbo
i dont get why everybody on this forum has to question someones motives when replying to their question. all i want to know is is it possible. i dont want to hear people telling me (regarding my own economies) that i should or shouldnt be worried about an extra 4.00 a fill up. thats my own problem, and i appreciate you pointing that out to me but
i do a lot of road trips in the summer and i use a lot of gas so it would be nice to know if this is an option.
Thursday, April 20, 2006 10:11 AM
Personally, I wouldn't consider a lower octane fuel an option. I agree with Shifted, even though he questions your economic situation (as you put it). I'm not one to fill up on 87 for a long trip then after the trip top off with 93..you've still got a lower octane fuel in your tank and lines.
Blown.
Thursday, April 20, 2006 10:20 AM
luke paxton wrote:ok. shifted, i know what you are saying and i completely agree, but the question was just that, a question. i know that a sc setup will be more reliable but for long trips i would like to know if i can use the lower grade fuel assuming im running 0 psi of boost. assuming that this is possible i would deal with the maintenance issues of the turbo
You honestly think you won't hit boost? Pass a car on the highway, give it a little too much gas merging into traffic, would really suck to blow your motor on a road trip if you cheaped out on gas by passing a car, tow trucks to tow your car home aren't cheap.
I'm not attacking you, I'm trying to save your ass, take it from somebody who HAS boost, you will be hitting boost even at times when you don't mean to, do it right, or don't do it, because it will end up costing you more in the end.
Thursday, April 20, 2006 10:36 AM
I think he was wondering about turning the boost down past what the wastegate spring is set at. (0 psi)
No, you can't. A boost controller can only turn the boost up.
Thursday, April 20, 2006 4:33 PM
You may be able to do it but it will take some good tuning to make it happen. I agree about financial conditions. Spending money at the gas pump if you don't need to is a waste. But you'll need $500 worth of software or $200 to $300 worth of aftermarket electronics to retard timing enough to safely use cheaper fuel. The cost difference for this purpose alone points to using the better fuel.
Marvel Mystery Oil, 4 oz to 10 gallons of fuel, can help increase fuel mileage slightly.
-->Slow
Friday, April 21, 2006 12:36 PM
Actually and granted this might not make up the difference but if you don't do anything stupid I drive around my car all the time with out really bossting much. The amount that I gained in power gave me less that I had to use the gas peddle. So now I am getting better gas mileage than I was. It's all a control factor. Especially if you are doing long trips. Where I used to get between 350-400 a tank. I am now see closer to the 400-420 a tank. The cost difference doesn't become much of a factor and I'm not worried about ever having trouble because of the wrong grade of fuel. The only time I complain about gas mileage is at the track. And well that is where I inteded to make more power, and power = efficient combustion of fuel so I can't really complaign much. Good luck with your decision and I think if you do it right either choice will make you happy t/c or s/c.
Friday, April 21, 2006 2:54 PM
even the GM supercharger i belive requiers a min of 92 octane? and there is NO way around not getting into boost with a supercharger... its just next to imposible as ther will always be a time your throttle is down just enough to close the by pass valve and build boost... turbo would be the same way...
spend the extra money.. get atleast 92 octane and dont cheap out... like every one has said.... you go cheap with somthing like that on a boosted engine... you might as well turn to the next person you see and just hand them $3000 ... it would probably go to better use the a turbo kit that going to granade your engine...
and dont know if octane boosters were brought up yet.. didnt read all of the posts.. but go for it use them... your going to need a dozen or so to make a difference... i read tests on them and the best one (cant remember the brand) raised the octane 0.6 ...... now add in the cost of one of them... that extra $5 or so a tank doesnt sound so bad now does it?
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
Friday, April 21, 2006 2:58 PM
depends on the tune....
How low can your wastegate go as a boost controller can't go lower then that. Boost doesn't have to be zero to use regular. Yes you can do it if you add enough fuel and tune so that you don't knock at the lower boost level.
Saturday, April 22, 2006 7:35 AM
Josh F wrote:turbo would be the same way...
ummm, wrong. Seeing as a turbo isn't controlled like the GMSC, that was a poor analogy. Many people, even with proper sized turbos can drive around w/o seeing positive pressure, as Encriptor has already stated. Now, if you have an oversized turbo on there (drag racing), you may not even see boost on the freeway.
fortune cookie say:
Saturday, April 22, 2006 12:37 PM
Yup, thats the main benefit of the turbocharger. You get bigger power when you need it and still get good gas mileage when you don't. I can drive my car around town all day long without making positive boost pressure.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Saturday, April 22, 2006 2:53 PM
i never seen a wastegate spring below 3psi, i can drive all the time no prob keeping out of boost but im never stupid enough to run anything below 93.
Saturday, April 22, 2006 6:03 PM
well then your saying only if the turbo is big and set up for drag racing.. because every single turbo car i have driven gets boost almost all the time... either merging, starting from a light, ect..... none of them were able to keep out of boost at all unless i wanted to drive like a grandma and get a huge a$$ line up going behind me... yes they dont stay in boost but all went into boost for some period of time...
Saturday, April 22, 2006 7:04 PM
I can keep mine out of boost no problem...
-Chris-
-Sweetness-
-Turbocharged-
Saturday, April 22, 2006 7:40 PM
well the only turbo Jbody i have driven is mine.. so it also has the supercharger on there which i guess is what is getting me into boost all the time even though it has the by pass valve.... but the gnx, turbo trans am, srt-4, eclipse and skyline that i have been in and driven all got into boost at one point or another even with out trying.. just accelerating normaly and merging into traffic as well as passing on the high way.. which this kid says he will be using it for road trips.. so unless he likes to get stuck behind slow trucks and what not and never passes any one... i dont think he should be using 87 octane... risking the $5 at MOST over 92 octane even...
Saturday, April 22, 2006 8:14 PM
Keep in mind the SRT stock turbo is very small... it boosts when you rev the damn motor.
I can barely get my BOV to go off when I rev up to 4500 rpm at idle.
It's all about turbo sizing.
-Chris-
-Sweetness-
-Turbocharged-
Saturday, April 22, 2006 8:56 PM
i cant get my blow off valve to go even when i rev my engine up... but then its cuz my supercharger isnt boosting either there for the turbo being too big with out the supercharger wont even come close to spooling at 4500+ rpm.. but yet under load its fully spooled to 12psi @ 1600 - 2000 RPM with a bigger then stock supercharger pulley on....
Saturday, April 22, 2006 10:31 PM
I guess you just don't know how to drive. I have driven a few boosted cars and was able to keep them all out of boost unless i wanted to.
Sunday, April 23, 2006 7:19 AM
Ronald Gill wrote:i never seen a wastegate spring below 3psi, i can drive all the time no prob keeping out of boost but im never stupid enough to run anything below 93.
You can run 87 on 3 psi if you wanted to. You could run it on 20 psi if you wanted to. There are more factors that play into required octane than just boost level. If you have the ability to correctly tune your engine you can pull a little timing to compensate. Installing pistons giving a lower compression ratio also allows for lower octance gasoline.
ex) slowolej is running 5-7psi on his 94 2.2L on a stock engine, no intercooler, running 87. He can do this because he was able to tune for it.
fortune cookie say:
Tuesday, April 25, 2006 7:36 AM
i can drive my Z around without hitting boost on the GMSC no problem. it's there if i need it but if i don't, it doesn't come on. takes a light foot i guess. i've run everything from 87 octane to 94 octane and found no difference in performance or knocking with my car. when we installed the SC we took it out for testing and found it was running proper A/F and under full boost and WOT it was only pulling 4 degrees of timing with the 87. granted this is with a MSD DISII set up.
Tuesday, April 25, 2006 8:38 AM
along the same lines... if you put in 93 octane and add a "octane booster" that you can buy over the counter. would that help at all? and if so by how much.. I know where I live there isn't any gas stations that have anything over 94 octane... granted I have never put anything less than 93 in my tank ever since I have purchased my t3super60 but I was wondering if this additive is any benifit???
**changes are here**
Tuesday, April 25, 2006 2:48 PM
Octane booster does nothing... i belive it was tested and the BEST results they could get were 0.6 more
