Starting - Boost Forum
Starting
Friday, January 27, 2006 9:14 PM
Something went wrong with my engine what ever it is well i found an excuse to built up my engine and turbo my car. but if ima do it might as well go big. I pulled the block out . im going big so i want my engine built right. my question is. what is the best kit for my engine 2.4l . what bore ? best prices ? i will worry about the turbo setup later i do have a t3/t4 though im lookin on boosting up to 20 psi . im getting a nice big fat incom tax check and might as well spend it on something good. and yes i have dont my research its just that everyone has a different idea on what to do . i plan on ordering all the internas and taking it to the machine shop all at once .
Re: Starting
Friday, January 27, 2006 9:47 PM
well to build the 2.4 engine properly...... for 20psi ...... your looking at in and around 6500...... USD............. that will get you everything you need.....
check out www.jbodyperformance.com
they build some SERIOUS motors....
Lee
JDM Civic Hatch
Re: Starting
Friday, January 27, 2006 10:12 PM
Lee wrote:well to build the 2.4 engine properly...... for 20psi ...... your looking at in and around 6500...... USD............. that will get you everything you need.....
Lee
6500? Think again...
Blew it up
Re: Starting
Friday, January 27, 2006 10:50 PM
D9 2.4L Twin Cam Piston Kits (1996-2002)
Kit A
80.00/3.543 Std. 3.701 1.181 61.5 5.5 8.740 10.5:1 .866 9000XX
Kit B
90.50/3.563 .020 94 30 61.5 5.5 222 22mm 9050XX
Kit C
90.00/3.543 Std. 3.701 1.181 61.5 -7.5 8.740 9:1 .866 9000XX
Kit D
90.50/3.563 .202 94 30 61.5 -7.5 222 22mm 9050XX
???? hurmmmm pistons now which one do i need and would the be cheaper to get them direct from the manufacturer ? to what bore is it safe to run high boost ? doesnt the forged piston have to fit to the bore on the block ?
ok well pistons Check next ? what else should i get that is essential to get ?
Re: Starting
Friday, January 27, 2006 11:34 PM
looks like Kit C is standard bore and 9:1 compression. I'd go with that for boost.
Re: Starting
Saturday, January 28, 2006 12:04 AM
Why not have a local machine shop/engine rebuilder shop do it for you and you buy the parts?
Re: Starting
Saturday, January 28, 2006 2:02 AM
Yea thats what i plan to do take it to the shop with all the parts that i want put in it. but theres alot of things dont know what is neccecary to make it last at high boost and that has the highest output of power . is there a list or sticky made before for parts to build a high boost enigine ? i got $2700 with my income tax and its all going to it. i may post pictures of every step. ive never had to build up a engine for boost. i had 240sx 98 turbo and a b22 hatch with turbo well i bought them like that just made little upgrades. but i really need some help doing this thanks
Re: Starting
Saturday, January 28, 2006 4:15 PM
?????... im ready to start ordering stuff the sooner the better .. anyone with good knowledge ? or someone who has a good setup what internals are yall running ?
Re: Starting
Sunday, January 29, 2006 2:47 PM
first off start withe basics.
clevitt 77 bearings
rods
mains
pistons w/rings
wisco
cp
ross
rods
egale
arp studs
main studs
head studs
head gasket
copper
oem
head
port polished
Re: Starting
Sunday, January 29, 2006 4:32 PM
i ordered the eagle rods. and now for which kind of pistons .040 or .020 ? what compression is better member i want high boost and i want it to last . and i also bought the complete gasket set for $200 and the clevitt bearings ....
Re: Starting
Sunday, January 29, 2006 5:14 PM
I LOVE HAVING A PUSH ROD MOTOR !!!!!! WOOT ........... so cheap to build up ....... haha ..
WOOT
Lee
JDM Civic Hatch
Re: Starting
Monday, January 30, 2006 3:14 AM
Juan Morales wrote:i ordered the eagle rods. and now for which kind of pistons .040 or .020 ? what compression is better member i want high boost and i want it to last . and i also bought the complete gasket set for $200 and the clevitt bearings ....
9:1 compression is good for a boost application. You don't really have to do an overbore. When you get too big of a bore, especially on a boosted motor, you can run into problems with your cylinder walls being too thin. Your option around that is to re-sleeve the motor but that's up to you.
If you still want to do an overbore, .020 is fine...just remember that you will have to get a shop to machine your block to fit the wider pistons and I believe your head gasket has to be modified or you have to order one to fit the block with a wider combustion chamber.
Re: Starting
Monday, January 30, 2006 5:59 PM
oh and to add to that ... o-ring the block for that copper custom head gasket ..........
Lee
JDM Civic Hatch
Re: Starting
Tuesday, January 31, 2006 4:29 PM
Ok... for the cams hurmmm they look to be expensive new so i guess ima look for the "secret Cams" for it. my aunt has a broke down 93 Grand amwith 53,000MIles with the 2.3l DOHC will does do ? or do they have to be from a cavy ?
Re: Starting
Wednesday, February 01, 2006 8:48 PM
.............. ok well out of all the Turbo cavys if looked up umm i think ive only seen one with some kind of Axels upgrade.... is there a certain company that makes then for High output engines ? cause if seen them turbo civics snap them like nothing. over here in texas there is some fast as imports running 6's in the 1/8 image the 1/4...
Re: Starting
Thursday, February 02, 2006 8:21 AM
How much is it or how much did some of you pay for your head to get ported and polished ? they are charging me $500 over i thinks thats a little too much isnt it ?
Re: Starting
Thursday, February 02, 2006 11:20 PM
Lee wrote:^^^^
Lee
no... you can use a stock head gasket on anything up to a .050 overbore. Which, a Cometic MLS will work even better. Plus, o-ringing is a pain in the ass.
Re: Starting
Friday, February 03, 2006 12:32 AM
Still cant find Axles.....
Re: Starting
Friday, February 03, 2006 10:57 AM
Juan Morales wrote:Still cant find Axles.....
JBP has axles.
JBP Axles
I guess they're listed for "3rd Gen's" and not specifically listed for particular years/engines. Are all 3rd gen axles the same? *shrugs*
