Hey Guys/Girls,
I have a 2003 chevy cavalier and I installed an after market radio. I knew about the features built into the radio and did without. Everything worked great, but for my birthday, my brother bought the kit that allows the features to be implimented while running the after market radio. You littereally have to install your original radio with the aftermarket....well, when he did this, the turn signals stopped working when used by the turn signal switch, if you run the hazards they work just fine. I tried checking every fuze but no luck...anyone got any ideas?
eddie
sounds like you need to take your car back to the dealer to fix the rear turn signal recall
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
sounds like a plan...didn't get that notice...the front ones don't work either, same problem?
As far as I know, the turn signals aren't even on the same circuit as the radio. I have an 03, and I'm perfectly happy without my chimes. If you want the chimes, go to any install shop, and ask for the GM Class 2 adapter. It has a harness and a chime module, that will reproduce your chimes and you can splice in a harness. I just splice my Alpine harness in right behind my factory harness so I didn't have to cut it off, and I don't care about chimes.
______________________________________
Hell hath no fury like a pissed off balloon animal.
"Sup, G?"
"Aren't you white?"
"Only on the outside, craka."
blinker fluid is low...that all...musta spilled some during the radio install....just goto autozone...its dirt cheap
lol sorry had to.....that sounds wierd to me......uninstall the aftermarket deck and reinstall yer factory one and go back to the dealer
Not unintentionally accelerating since 2009!!!!
yup...it is mainly the rear bulb sockets...they bulbs don't blow but they are loose or something. i replaced my drivers side rear one 3 times in one year before i got the recall notice about it.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Yea, I relaced my rear driver side twice the first year I had it...thought it was wierd, but figured it was just coincindence....I've contacted my local dealer and am taking it in for repair tomorrow...thanx for all the help.
