I would like to get to subs and 1 amp if possible, need some advice
Memphis m3 dual voice coil
RMS/Peak (W) 400/800
Sensitivity (dB) 95.8
Magnet SIze (oz) 85
Mounting Depth (in) 6.1
Memphis 1500 x1 class D
1500 watts x 1 @ 2ohms
Is that dual 4 or dual 2 ohm? If it's dual 2 ohm, you can run them series/parallel to give you a 2 ohm mono load, but make sure your gain is down on that amp, so you don't blow yer speakers.
Beat it like it owes you money
gains are meant to lower or raise the power ratings of an amp
i learned that the hard way
^^you mean NOT meant...
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
gains are there to match the amp to the pre-amp voltage coming from the headunit.......... gains are NOT a power knob, OR volume knob
That'll be nice. I have a 1200 watt amp on my 2 MClasses and they can take it.. A buddy of mine had a 2500 watt amp on one 12 inch M3, with the gain almost maxed (not a good thing i know but just trying to make a point). You should be fine with 1500 x 1.
<img src="http://rage.webspiffy.com/images/sig.jpg">
with the gain maxed, its not the power you have to worry about, its the distortion.... the sub will stay at its full excursion, and this will not allow the coils to be cooled, and then you have a melted coil and a blown sub
sndsgood, that is what i meant, used the wrong word.... thanks for the correction
yea forgot the word "not" lol
i looked like an idiot hahah
