turn signal - Audio & Electronics Forum
turn signal
Sunday, February 13, 2005 1:39 PM
Hey guys I drive a '95 Sunfire GT. I find every now and then that my turn signals don't flash. It still comes on but it stays on. It does it on both sides and it doesn't seem to matter if it's warm or cold out. The worst part is it only does it every once in awhile. like I'll use it and it works find then the next time I try them it just stays on. All the bulbs are good, plus I thought if it's a bulb it just flashes faster. So could it be the flasher unit it'self or could it be the switch coming out of the steering column? Any help would be great.
Re: turn signal
Sunday, February 13, 2005 2:04 PM
If it stay on this is prob just the switch or a short (very hard to find)
2 x Adire Brahma 15", 2 x PA A3000DB
Re: turn signal
Sunday, February 13, 2005 5:22 PM
be sure and check yoru blinker fluid you could be running low on that and gettin air bubbles
Re: turn signal
Sunday, February 13, 2005 6:05 PM
heretic wrote:be sure and check yoru blinker fluid you could be running low on that and gettin air bubbles
Hey check your horn strap and your wiper radiator. also
Re: turn signal
Sunday, February 13, 2005 7:58 PM
Could be a loose bulb. either it blinks twice as fast when a bulb dies or it doesnt blink at all. i forget
____________________
84 Fiero So stock it hurts
Im in the everybody club are you?
Re: turn signal
Sunday, February 13, 2005 9:04 PM
J K wrote:Could be a loose bulb. either it blinks twice as fast when a bulb dies or it doesnt blink at all. i forget
When a bulb is blow it flash faster
