Just picked up a 98' Z24 with a odd "feature".
In order to start the car you have to hold down the left turn signal.
Whats this about?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
Nice! Did you trace wires yet?
i <3 bootched installs.
car audio noob since 1984.
lol thats awesome. i want to do that
*think* Ok so our cars have 3 ignition, one accessory, 2 constant power and a starter wire. Now if someone fed one of the ignition wires to the turn signal switch and then to the car, then it would only start if the turn signals were on. I hope they put in a relay and a diode.
its a starter kill...thats kinda cool as long as a relay was used....which im sure it was or it wouldnt work.... I worked on a maxima where teh car wouldnt start unless you pressed the side mirror switch to teh right.... thats just there to prevent some one from stealing your car
someone could really use this when they have a push start and bypassed the key itself. is that possible?
03 cavalier
us amps 100hc running at .5 ohms
digital designs 3512
yellow top g34
kenwood ddx-8019
Id say probably but very stupid.
why would it be stupid?
03 cavalier
yellow top g34
kenwood ddx-8019
sikcavy wrote:why would it be stupid?
easier to steal if someone knows about it, probly.
how would you go about doing this little mod?
switch in between the ignition switch and starter wire.
but if u have a special security feature where you had to hold something down, im pretty sure nobody would go around holding things down trying to start your car.
03 cavalier
yellow top g34
kenwood ddx-8019
I agree, I think its a pretty smart idea, but more than likely, if anything is going to get stolen, its going to be the contents of the car, not the car itself.
Its stupid because your "secret" wont be a secret very long. One person sees it and that can go a long way.
please, if you are the only person to drive your car, when you hop in, you just turn the key while pushing down on the turn signal, you can do that pretty stealth without anyone noticing.
If one person does, you can play it off like its nothing. Something you just do... or whatever.
i might actually do this lol i like the idea. screw keys
03 cavalier
yellow top g34
kenwood ddx-8019
Im going to chuckle when you post up asking for help finding your stolen car.
sikcavy wrote:i might actually do this lol i like the idea. screw keys
You're going to need a few more things to get it to work with Passlock.
really? would you mind explaining? i havent had to do anything with passlock yet so im new to that whole ballpark
03 cavalier
yellow top g34
kenwood ddx-8019
I kind of like the idea of a security feature like this. If I did one, I'd try and put an override or turn-off on it so if I had to leave the care with someone or have someone else drive it (that I didn't trust), I wouldn't have to give the secret away. Good luck with it.
The only dead give away is every time you start the car... your left turn signal is on.
ya but we could do something with say the dimmer switch cause when u first get in ur car, ur light is on and when u start it it goes off.. it wouldnt be too noticable.
03 cavalier
yellow top g34
kenwood ddx-8019
So explain how youd do it when you have to say take your car in for service?
well what kind of service? cause i do mostly all my own work... and i could just leave the key hooked up so that i have both but not "HAVE" to use a key.
03 cavalier
yellow top g34
kenwood ddx-8019
It seems like a lot of work for something that you arent gaining anything out of. You still have to carry keys to get into your car unless you plan on leaving it unlocked all the time.
