ok quick question, i went to do the high beams and fog lights mod yesterday and when i opened the hood i only saw one relay box under the drivers side headlight. In the write up it says theres supposed to be two relay boxs and i can only find one of them. Am i not looking hard enough or am i just missing something? thanks in advance.
im guess you wanna use your high beams and fogs at the same time?? why not just get some relays and wire em up? i would wire the fogs to your parking lights that way when ever you turn on your parking lights the fogs come on....
Why not hit the rocker switch when you turn your high beams on
the fogs turn off when you hit the high beams, have you never noticed that? just keep following the wires and you should find it. otherwise, just re-run the wires right off the fogs.
yes i notciced that and all i was wondering is where the second relay box is? in the library section theres a write-up on how to bypass that by spliceing some wires together i just cant find the right wires.
like i said just use some relays....
