Ok so i got in my car this evening and i went to use my high beams and they dont work! @!#$! So when i hit the arm to turn the high beams on it just flips my DRLs on! everything else works!
What kind of bulbs are you using? Sounds a bit like a melted harness to me.
check the bulbs...if they are good then check the harness, i know in my 04 there where like 6-8 wires with the cooper all corroded. Most of the corroded wires were on the ends by the end of each radiator.
