Do I have enough amp for this speaker (or enough speaker for the amp)? - Audio & Electronics Forum
Sunday, May 13, 2007 12:32 AM
Alpine MRP-450 rated at 220W RMS x 1 @ 4 ohms, 400W RMS x1 @ 2 ohms
Infinity 1050W 10" sub rated for 250W RMS, 1000W peak, single 4 ohm voice coil.
Thanks.
Re: Do I have enough amp for this speaker (or enough speaker for the amp)?
Sunday, May 13, 2007 12:55 AM
Yeah, but you're missing out on a lot of extra power by going 4-ohm instead of 2-ohm.
Sunday, May 13, 2007 12:56 AM
Also, I did a good bit of Googling on how to setup the amp, and got all confused by gain, lowpass filter, and bass eq. Those are the adjustments possible with this amp. I found precisely zilch info on how to setup this particular amp. Right now I have gain turned up a good bit, the eq turned up, and the lowpass set at 200hz. Does that sound right? Thanks.
Sunday, May 13, 2007 1:27 AM
For a sub I would bring the the crossover down to 60-80Hz
Here's a tutorial about how to set your gains
http://www.j-body.org/forums/read.php?f=4&i=133672&t=128637&p=1
Keep in mind, if you want to use Bass EQ, set the gain while playing a sine wave the same as the center frequency. (With Alpine I think it's 45Hz, check the manual)
Good luck.
Sunday, May 13, 2007 1:51 AM
bradsk88 wrote:Yeah, but you're missing out on a lot of extra power by going 4-ohm instead of 2-ohm.
How would I wire up 1 single voice coil sub (the above mentioned Infinity) to put a 2 ohm load on the amp?
Sunday, May 13, 2007 1:56 AM
bradsk88 wrote:For a sub I would bring the the crossover down to 60-80Hz
Good luck.
I didn't find anything in the manual that mentions "center frequency" but I DID find something that said Bass EQ...........50Hz, +12dB Variable. Is 50Hz the center frequency then? And thanks for the responses.
And as an edit to my above post, I got the infinity sub on sale at CC for 70 bucks last february, I needed something to replace my ages old Planet Audio sub that had seized the voice coil. I am considering getting an ED 11Kv.2 sub to replace the infinity though sometime this summer, after I upgrade my 6x9's.
Sunday, May 13, 2007 10:06 AM
No problem. You said your sub is a single voice coil, so unfortunately, you CAN'T wire it in two ohm. One option you have is to grab another of those subs and wire both of them in parallel, then you would get 2ohms.
From the look of it, yeah 50Hz should be the center frequency. You could confirm it by playing a bunch of sound files, 30Hz, 40Hz, 45Hz, 50Hz, 55Hz, 60Hz, etc with the volt meter attached to the output leads. The one that reads the highest voltage (after bass EQ is ON) is the one you want to tune on.
11kv.2 are supposed to be beautiful subs. I've been trying to convince myself to buy 2 of them forever But I'm cheap.
Sunday, May 13, 2007 11:56 AM
Saw the 11kv.2 on ebay for 80 bucks.
Sunday, May 13, 2007 12:06 PM
Yeah, they're crazy cheap...................IF you live in the states
Sunday, May 13, 2007 2:09 PM
i have that same amp. what do you guys figure the MAX output is at 2 ohms. im trying to get an idea of how many watts my subs are gettin
Sunday, May 13, 2007 2:11 PM
From what I've observed with Alpine amps and how they rate them, it's probably something around 1000-1200 thumping watts.
