hello everyone,
im trying to install keyless entry on my 1998 chevy cavalier 2.2. The car has power windows and locks. i searched the forums and i still cant find where to wire this wires. I have a Computar CM4200. Heres the wires from the starter/keyless:
Violet White - (-) Trunk Unlock Output
Orange/Black - (-) 2nd Pulse Unlock Output
Blue - (-)Unlock Output
Blue/Black - (-)Lock Output
Where do i put those wires? Thanks Guys and Girls.
Since you have keyless, you'll have to use relays to turn the plunger's trigger to negative. Power lock is light blue, power lock is white. Check with a multimeter to make sure you have the right wires - when you press the lock, the light blue should show 12 volt, and when you hit unlock, the white should show 12 volt. You'll use this:
, one for lock, one for unlock. The unlock, where it says +12, it'll goto the white wire, the lock, it'll goto the light blue wire.
