Can anyone tell me where the "Fuel Tank Vapor Pressure Switch" wires end up at in the Engine Compartment. I need to find the Gray Wire (15) that gets the PCM (C3-13) 5V Ref Voltage that is tied to the A/C Pressure Switch, MAP Sensor, and the I/P (H6).
I've found everything but the wire to the FTVS. Does it come through the Bulk Head Connector ?
Thanks for your Help...
