i have a 1997 sunfire gt and when i have my subs turned up at a low RPM they have a tendincey to cut out...i just replaced the alternator like 3 weeks ago...and battery...does anyone else have this problem or had?..and if so what did u do to fix it?...thanks for you time any and all comments will be greatly apprciated!
Your subwoofers, or your amplifier is cutting off??
Sounds to me like a voltage problem. Use a dmm to test the votlage at the amp during play.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
check and see if your amp is going into protection. some amps have a thermal and other types of protection which is usually indicated by an LED or the power LED turning a different colour than normal.
1997 RedR - ZedR
mine use to do the same thing and i couldnt figure it out. i had good voltage to it. i thought it was the sub and amp combo but then it got stolen before i could figure it out. haha
