4 ch bridged vs 2 ch - Audio & Electronics Forum
Monday, February 05, 2007 7:25 PM
Got the option of 2 amps. Using to run 2 infinity Kappa 6x9's , 100rms I believe. Am I better off with a 2 ch or a bridged 4 channel? They're both the same price. Will I lose stereo sound when I bridge the 4ch? Does this really matter with the rear 6x9's? When bridging the 4 ch I would bridge the front 2 ch to run one speaker and the rear 2 ch to run the other correct? Any insight or suggestions would be appreciated. Thanks
MTX 4202
2 Ch
Power 12.5 VDC Input
2 Ohm Load 100 w x 2 Low Level
4 Ohm Load 50 w x 2 Hi Level w/ Smart Engage
Bridged 4 Ohm Load 200 w Crossover(s)
Power 14.4 VDC Hi / Low @ 85Hz
2 Ohm Load 140 w x 2 Fixed, Defeatable
4 Ohm Load 85 w x 2 RCA Output
Bridged 4 Ohm Load 280 w Full Range Only
MTX 4244
4Ch
2 Ohm Load 60 w x 4 Low Level, Input Select
4 Ohm Load 45 w x 4 Hi Level w/ Smart
Bridged 4 Ohm Load 120 w x 2 Crossover(s)
Power 14.4 VDC Hi / Low @ 85Hz -
Rear Fixed, Defeatable
2 Ohm Load 100 w x 4 Hi Pass @ 85Hz -
Front Fixed, Defeatable
4 Ohm Load 55 w x 4 RCA Output
Bridged 4 Ohm Load 200 w x 2 Full Range Only
