i got this keypad starter.....and was wondering if anyone got this keypad aswell.....or if anyone can help me install it. i tryed once, and it didnt turn out good.......but i deff think that was because of my lack of knowledge of cars, and their electrical/starting system.
this is what i got :
keypad starter
this is the diagram that came with it.....
and this is the part that i dont get....
like...what wire am i supposed to cut....and where does the green, and yellow wire go.....
if anyone could help me out at all, i would really appreicate it!!!
thanks in advance!!!
~Shiba~
what they have it designed to do force the code to be entered before using the key cylinder, this way ONLY the keypad can start it
on a side note: trying to be the transporter??? lol
Edited 1 time(s). Last edited Friday, November 24, 2006 9:08 PM
Looks like you cut the starter wire (from the ignition switch to the starter), and connect the key side to the yellow wire, and the starter motor side to the green wire.
I'm almost certain that's the yellow wire in the steering column... but I'm at work, and it's nearing the end of a terribly long day... so maybe wait til someone else chimes in to confirm the wire colour
yea, i got the general idea of what its supposed to do.....
and yea, i was kinda goin for the transporter thing.....
thanks guys.....anyone else have any ideas?!?!?!
Are you planning on having the key in the iginition too? If not you'll need to bypass the passlock system for it to work.
-Chris
yea, how it works, is you stick the key in and turn to the on position....type in the code....then u can turn the key to the crank position to start the key......i was planing on hooking up a start buttion once i got this keypad thing working....
Man they marked up the price on those things, I payed 40 when I got mine. But you got a completely different system, here's what mines was wired like (same as your's) except it also had a brown wire to a fuse.
Getting "better built" for the '08...
what was the brown wire for???
and where did u put the yellow and green wires??....thats my main problem...i have no idea where they are supposed to go.....my first guess ended up in my car not starting for 1 week......so i'm hesitant to try again....
thanks again!!
~Shiba~
From the picture you connect the green wire to the starter solenoid and the yellow wire to the ignition wire... so you by pass the point of them both connecting like normal. enter password and bingo ur the new transporter.
5 seconds to find another street...
ok, i think i have a general idea of where the ignition wire is......and i know where the starter solenoid is.....but which wire........theres a relay, and idk which wire i need to do.....
it should be the pink wire
by the key?.....or by the starter?
i'm hoping u mean by the key, cuz the relay only has black and red wires....lol
key
then i just cut it, and put yellow on the side of the key, and green on the other side??
yup
