I'm installin my gauges and im goin to be usin the switched pink wire in the steerin column, but my question is what is this pink wire actually for? I'm just wonderin that this wire is used for in the dash. one more question, i got a vaccum gauge and it came with the hose and a t fittin, what hose in the engine bay should i hook this up too?
I NEED A 00-02 SUNFIRE RK SPORT REAR LIP AND A 95-99 SUNFIRE WW FRONT LIP PLEASE LET ME KNOW IF U WANNA SELL!!
I believe the pink wire goes to the cruise if you have it. The vacuum gauge should hook between the FPR and the intake on the engine.
i thought the obnoxious pink wire was reserved for the air bag
There's quite a few pink wires in the car... you'll have to specify which pink wire you're talking about
the pink wire in the steerin column that everyone says to hook your gauges too. Got a picuter of the vaccum line anyone? and 2 of the gauges have orange wires and the schims say they are to hook up to a "headlamp" 12V other source and connect to 12v lighting, im guessin this means the head light switch, right? Why would only 2 of them need ot be lite up tho? the 2 that have it is Vaccum and Oil Pressure. Their tinted gauges so u'd think they would need t be light all the time.
well theres only one pink wire in the steering column and its the primary ignition wire and you shouldn't directly tap to that unless you have a alarm to wire a remote start of starter kill, if you have the 98 sunfire then its like mine it has 2 ignition wires pink and white, tap to your fuse in the fuse box for those guages, the direct ign line has a lot of power and can spike as well as send a lot of ripples through your audio system, like a hum in your stereo.
jason
gmto2nr
mecp gold certified
any more questions pm me and keep this: you might need it
Constant 12V+ Red (2) Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Ignition 2 White Ignition Switch Harness PCM and Cluster
Accessory Orange Ignition Switch Harness (Heat/AC)
Tach White (AC) Harness near Battery
Neutral Safety Wire Yellow Ignition Switch Harness
Brake Switch White Brake Switch
Trunk Release Black/White (+) OEM Keyless Module Driver's Side of Trunk
Trunk Pin Black (+) Light in Trunk
Parking Lights Brown (+) Parking Light Switch or Driver's Kick Panel
Head Lamp Dark Blue (-) Pink (-) at Head Light Switch
Door Trigger Green/Black (-) And LT. Blue Block near Brake Diode Isolate
Door Lock Light Blue Either Kick Panel (Passenger's Switch is Master)
Door Unlock White Reverse Polarity
Driver's Lock Gray Left Kick Panel
Driver's Unlock Tan Left Kick Panel
Passenger Unlock White Left Kick Panel
Horn Wire Black (-) HEADLamp Switch
Windows Up LF=Dark Blue, RF=Light Blue, LR=Dark Green, RR=Light Green
Windows Down LF=Brown, RF=Tan, LR=Purple, RR=Purple
still dont know what wire to use for the red and orange wire
yea im sitll lost lol i've been lookin at that diagram and im still lost. Anyone help me? and i sent you a pm jason dotn know if u got it or not
