What size box do you have? - Audio & Electronics Forum
Friday, October 27, 2006 9:51 AM
Built a box this weekend and it didnt fit into the trunk(would have fit inside just couldnt get it in.) So I need a fairly large box like 4cuft to house two 12"s so if anyone has a box they built could you give me the dimensions so I know what will fit. Tried measuring but theres so many factors on if it will or wont fit. Any opinions?
Re: What size box do you have?
Friday, October 27, 2006 10:16 AM
stick it in through the backseat
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Friday, October 27, 2006 10:17 AM
tried that but it is to long to get to turn it especially with the diagonal pieces behind the back seat(under the panels) so Im just gonna build a new one tomorrow. Just looking at what size I should do.
Friday, October 27, 2006 10:24 AM
just cut em out, it'll allow for a 4 cubic foot box easy...although i slid a 4 cubic foot box with a port in through the seats without cutting....but i'd suggest cuttin em out, they're useless
LOL
Friday, October 27, 2006 11:06 AM
yes, cut those out. You can fit a 36" wide box, and around 16-17" tall, depth is only limited by what you can cram through your door, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Friday, October 27, 2006 11:08 AM
I fit a box 36x17.5x24 in there through the back seat
Friday, October 27, 2006 11:10 AM
why you making the box so big????
did you get the correct dimension required for that sub???
becasue making a big box doesn't help your sound it makes it worse...
"Silver 2001 Cavalier z24 5 speed 2 door sunroof and power everything "
AEM Short Ram Intake
B&M Short Throw Shifter
Friday, October 27, 2006 11:24 AM
Joe Peps wrote:why you making the box so big????
thast a pretty broad statement and one that can be proved wrong pretty easily. every sub requires a diffrent sized box so i wouldn't throw that out there.
Friday, October 27, 2006 10:09 PM
if you read what I said... I basically said the same thing as you...
If you make a box bigger than your subs specs, it will sound off
Saturday, October 28, 2006 1:32 AM
n8ball2013 wrote:I fit a box 36x17.5x24 in there through the back seat
same here but only 16.5" high everything else the same
outcasts
Sunday, October 29, 2006 1:23 AM
Most of my boxes for probably 90% of my subs have been bigger then spec. They didn't sound off.
Mike Roth
Sunday, October 29, 2006 6:08 AM
Joe Peps wrote:if you read what I said... I basically said the same thing as you...
i read it as if you were saying big boxes sound bad.
